Home > Forums > OpenFOAM Running, Solving & CFD
Error message in InterFoam
Old   February 13, 2009, 06:04
Default Hi, I've adapted the geometry
Gareth
gareth__it_power is on a distinguished road
I've adapted the geometry of the damBreak tutorial in InterFoam, and have checked that the blockMeshDict file is correct. blockMesh and setFields both run fine, but upon executing interFoam, the following is returned. Is it possible to tell from this error what the problem is?
Thanks
gareth
Exec : interFoam
Date : Feb 13 2009
Time : 10:03:21
Host : itpower-desktop
PID : 9203
Case : /home/itpower/OpenFOAM/itpower-1.5/run/interFoam_enclosedWalls_newMesh
nProcs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
#0 Foam::error::printStack(Foam:stream&) in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xb7f82420]
#3 Foam::surfaceInterpolation::makeDeltaCoeffs() const in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::surfaceInterpolation::deltaCoeffs() const in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so"
#5 Foam::fvPatch::deltaCoeffs() const in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so"
#6 Foam::fvPatchField<double>::snGrad() const in "/home/itpower/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interFoam"
#7 Foam::fv::gaussGrad<double>::correctBoundaryCondit ions(Foam::GeometricField<doub le,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh>&) in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so"
#8 Foam::fv::gaussGrad<double>::grad(Foam::GeometricF ield<double,> const&) const in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so"
#9 Foam::tmp<foam::geometricfield<foam::outerproduct< foam::vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<double>(Foam::GeometricField<doubl e,> const&, Foam::word const&) in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libinterfaceProperties.so "
#10 Foam::tmp<foam::geometricfield<foam::outerproduct< foam::vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::grad<double>(Foam::GeometricField<doubl e,> const&) in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libinterfaceProperties.so "
#11 Foam::interfaceProperties::calculateK() in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libinterfaceProperties.so "
#12 Foam::interfaceProperties::interfaceProperties(Foa m::GeometricField<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::IOdictionary const&) in "/home/itpower/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libinterfaceProperties.so "
#13 main in "/home/itpower/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interFoam"
#14 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#15 Foam::regIOobject::readIfModified() in "/home/itpower/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interFoam"
Floating point exception
gareth__it_power is offline   Reply With Quote
Old   May 25, 2011, 16:54
Walter Schostak
wschosta is on a distinguished road
Since this is two years later, I hope you've resolved your problem but in the event that you haven't, it looks like your error is emanating from the createFields.H file. I don't know what you changed so it's hard to say exactly what is wrong but I have been dealing with interFoam a lot in the past few weeks and seen more than my fair share of error messages.
If you're still looking to solve it post your code and I might be able to help.
Regards.
wschosta is offline   Reply With Quote
Old   June 2, 2011, 12:02
Default Floating point exception
huxiaoxia
huxiaoxia is on a distinguished road
I have the same problem as it described above. I just change the boundary left and right conditions from wall to cyclic, and I didn't touch the creatFields.h file. But I got the same error. Therefore, can you help me with that?
Thanks a lot.
huxiaoxia is offline   Reply With Quote
Old   June 2, 2011, 15:16
Walter Schostak
Are you sure it's the exact same error? Did you make sure to run blockMesh and setFields (or the appropriate ones for your solver) before running your solver?
If you post the beginning of your log file as Gareth did, someone on here might be able to give you a better answer.
Old   June 3, 2011, 10:46
huxiaoxia
Here is the log file:
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.1-03e7e056c215
Exec : interFoam
Date : Jun 03 2011
Time : 10:43:30
Host : ip11
PID : 22479
Case : /home/huxiaoxi/OpenFOAM/huxiaoxia/temporalnew
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Reading field p_rgh
Reading field alpha1
Reading field U
Selecting turbulence model type LESModel
Selecting LES turbulence model oneEqEddy
oneEqEddyCoeffs
ce 1.048;
ck 0.094;
Reading g
time step continuity errors : sum local = 4.2484e-25, global = -2.28964e-25, cumulative = -2.28964e-25
GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 2.6484e-06, No Iterations 7
GAMGPCG: Solving for pcorr, Initial residual = 0.0221807, Final residual = 1.23886e-06, No Iterations 5
time step continuity errors : sum local = 1.24084e-17, global = 1.8688e-18, cumulative = 1.8688e-18
Courant Number mean: 1.13971e-06 max: 5.00472e-06
Starting time loop
Courant Number mean: 0.0113857 max: 0.0499972
Interface Courant Number mean: 7.56989e-10 max: 0.000258632
deltaT = 9.99001e-08
Time = 9.99001e-08
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::tmp<Foam::Field<Foam::Vector<double> > > Foam:perator/<Foam::Vector<double> >(Foam::UList<Foam::Vector<double> > const&, Foam::tmp<Foam::Field<double> > const&) in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#4 Foam::LimitedScheme<double, Foam::vanLeerLimiter<Foam::NVDTVD>, Foam::limitFuncs::magSqr>::limiter(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#5 Foam::limitedSurfaceInterpolationScheme<double>::w eights(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libinterfaceProperties.so"
#6 Foam::surfaceInterpolationScheme<double>::interpol ate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libinterfaceProperties.so"
#7 Foam::fv::gaussConvectionScheme<double>::interpola te(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#8 Foam::fv::gaussConvectionScheme<double>::flux(Foam ::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/lib/linux64GccDPOpt/libfiniteVolume.so"
#9 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::fvc::flux<double>(Foam::GeometricField<doubl e, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/interFoam"
#10 main in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/interFoam"
#11 __libc_start_main in "/lib64/libc.so.6"
#12 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/huxiaoxi/OpenFOAM/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt/interFoam"
Can anyone help me with that?
Old   June 5, 2011, 08:00
Default Error message in InterFoam
ata
ata's Avatar
ata kamyabi
ata is on a distinguished road
Hi
I think may be you should use better BC our better initialization.
ata is offline   Reply With Quote
Thread Tools
Trackbacks are On
Error message-Floating point error Vaibhav FLUENT 3 December 7, 2007 06:38
ERROR MESSAGE: line 1: parse error Lourival FLUENT 1 February 18, 2006 02:35
Error message, help, plz UY CFX 1 August 11, 2005 17:18
help on an error message Sri FLUENT 1 November 24, 2003 10:34
Gambit 2.0 - Error Message (ACIS ERROR 1200) James FLUENT 1 May 14, 2003 08:13
