Steady state transsonic turbulent flow
Old   December 19, 2008, 04:19
Default Hello, I'm trying to valid
Mathias Kvick
kvick is on a distinguished road
I'm trying to validate some experimental data for steady pressure measurements on a 3D wing with a Mach number of 0.8.
I've been trying to use rhoSimpleFoam, but the pressure gets very high after just a few iterations. After reading on the forum, I understood that rhoSimpleFoam is not good for trans-sonic flows.
Therefore I have an idea of trying to modify sonicTurbFoam to solve a steady state calculation, but I'm not sure how to do that.
Any help or suggestions are most welcome, thank you for your interest.
kvick is offline   Reply With Quote
Old   December 25, 2008, 08:09
Default Hi again, I have not manag
Mathias Kvick
Hi again,
I have not managed to modify sonicTurbFoam to a steady solver, so instead I'm doing a transient calculation on my case. However, it is starting to diverge after a while, and I don't understand why. I'm thinking there might be something wrong with my mesh, the result from checkMesh can be seen below.
The problem is set up by a 3D wing in a half-sphere far field, the mesh is completely tetrahedal.
Mesh stats
faces: 2231127
internal faces: 2161985
cells: 1098278
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Number of cells of each type:
hexahedra: 0
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 1098278
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
far-field 1206 632 ok (non-closed singly connected)
symm 5520 2885 ok (non-closed singly connected)
arw_trailing 506 508 ok (non-closed singly connected)
arw_tip 730 433 ok (non-closed singly connected)
arw_lower 30529 15611 ok (non-closed singly connected)
arw_upper 30651 15672 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-2.08446e-14 -22.5 -22.4974) (22.4989 22.5 22.4974)
Mesh (non-empty) directions (1 1 1)
Mesh (non-empty, non-wedge) dimensions 3
Boundary openness (1.04741e-18 7.20372e-19 2.7995e-19) OK.
Max cell openness = 1.64485e-16 OK.
Max aspect ratio = 8.5273 OK.
Minumum face area = 3.30537e-06. Maximum face area = 5.81775. Face area magnitudes OK.
Min volume = 3.02341e-09. Max volume = 3.70366. Total volume = 23746.7. Cell volumes OK.
Mesh non-orthogonality Max: 74.3269 average: 19.577
*Number of severely non-orthogonal faces: 38.
Non-orthogonality check OK.
<<Writing 38 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.845377 OK.
Mesh OK.
End
Please tell me what information is of interest and I will post it here.
I appreciate any help I can get.
Old   February 12, 2009, 04:36
Default Dear Mathias, did you manage
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Dear Mathias,
did you manage to solve your convergence problems? I am facing the same difficulties as you did for a subsonic, steady state and turbolent flow around a wing (I am using simpleFoam), see the complete discussion here. Maybe you could give me some advices...
Thanks,
Maddalena
maddalena is offline   Reply With Quote
Flow-3D for Steady State Simulation CK Main CFD Forum 5 March 2, 2021 06:29
Steady state incompressible flow Bharat Rangan (Rangan) OpenFOAM Running, Solving & CFD 10 November 22, 2010 15:21
Getting steady-state solution for turbulent model? Kwontona FLUENT 0 February 23, 2007 17:14
Damp turbulent behaviour for a steady state calculation andimb OpenFOAM Running, Solving & CFD 0 May 4, 2006 05:39
steady state creeping flow dominik Main CFD Forum 4 March 29, 2004 09:29
