-   -   Drag of a sphere in laminar flow (http://www.cfd-online.com/Forums/openfoam-solving/58003-drag-sphere-laminar-flow.html)
harly February 3, 2009 15:40
Hi, I have a 3D case runnin
I have a 3D case running of a sphere(d=1) with Re=50 and I want to determine the drag.
I used the following in my controlDict
functions
forces
type forces;
functionObjectLibs ("libforces.so"); //Lib to load
patches (sphere_GmshSphere); // change to your patch name
rhoInf 1.22; //Reference density for fluid
CofR (0 0 0); //Origin for moment calculations
forceCoeffs
type forceCoeffs;
patches (sphere_GmshSphere); //change to your patch name
rhoInf 1.22;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 0.000753;
lRef 1;
Aref 0.785398;
and
nu nu [0 2 -1 0 0 0 0] 1.5e-05;
in transportProperties
the problem is now , that my drag is too high(about 7 what should be 1.5).
Can someone see the a mistake or shall I blame the Grid ?
If someone has a case which gives good results for a laminar flow I would be happy about every input.
- Daniel
wolle1982 February 4, 2009 06:27
hi, when did simulation on
hi,
when did simulation on an airfoil, i also had too high drag. the distance to toe far boundary edge was 40 times the airfoils chord length. increasing to 100 times the chord length improved it.
--> try make the grid around the sphere very huge!
and yes, the grid is a very sensitive factor to the results. try not to get too great skewness near the boundary layer. and also refine the mesh behind the sphere.
