-   -   Oscillating velocity inlet (http://www.cfd-online.com/Forums/openfoam-solving/58014-oscillating-velocity-inlet.html)
xiuying October 8, 2007 19:24
Hi, I began to use Openfoam s
I began to use Openfoam simulating a rough channel flow with turbulent model and oscillating velocity inlet. I wrote the file /0/U as follows. But when I run it, The wrong is like the following. Could you tell me how to deal with problem. Thank you.
Kang
Nprocs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM FATAL IO ERROR : wrong token type - expected Scalar found on line 36 the word 'uniform'
file: /OpenFOAM/xiuying-1.4.1/run/tutorials/turbFoam/rough/0/U::amplitude at line 36.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 85.
FOAM exiting
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type oscillatingFixedValue;
refValue uniform (0 0 0);
amplitude uniform (1.0 0 0);
frequency 100;
value uniform (0 0 0);
outlet
type zeroGradient;
upperWall
type slip;
lowerWall
type fixedValue;
frontAndBack
type empty;
mattijs October 9, 2007 04:14
It says that at line 36 it exp
It says that at line 36 it expects a scalar but is reading 'uniform'.
My guess is that the amplitude and frequency are all single scalars. Check the source code (finiteVolume/lnInclude/oscillatingFixedValueFvPatchField.*) to make sure is my advice.
xiuying October 9, 2007 17:07
Hi,Mattijs, The velocity is
Hi,Mattijs,
The velocity is a vector. Please tell me how to deal with the problem. Thanks.
Kang
patriem February 1, 2009 12:53
Hello, did you handle that
did you handle that problem? I am at the same point at the moment...
Would be great if someone could help finding a solution.
Regards,
Patrick
daniels February 2, 2009 03:05
Hi, amplitude is a scalar,
amplitude is a scalar, try
inlet
refValue uniform (1. 0 0);
amplitude 1.0;
frequency 100;
(You can find out what type is required in line 59ff of src/finiteVolume/fields/fvPatchFields/derived/oscillatingFixedValue/oscillatingF ixedValueFvPatchField.H)
Daniel
