hallo all,
i am student and n
hallo all,
i am student and new at/in (?) OpenFOAM i am just trying my first case in OpenFOAM (surface tension of a water , in a square, with contact angle with and without gravity) solver: interFoam so, it's all really pretty at yet i just want to deal with interDyMFoam and dynamic refinement. in 3D its all ok, but i have no idea how can i dynamic refine in 2D i get following error: Starting time loop Courant Number mean: 0 max: 0 deltaT = 0.001 Time = 0.001 Selected 56 cells for refinement out of 5400. Refined from 5400 to 5792 cells. Selected 0 split points out of a possible 56. Execution time for mesh.update() = 0.18 s This mesh contains patches of type empty but is not 1D or 2D by virtue of the fact that the number of faces of this empty patch is not divisible by the number of cells. From function emptyFvPatchField<type>::updateCoeffs() in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 148. FOAM exiting Thanks in advance. Greetings, Ala |
Hello Ala and welcome,
The ab
The above message says that you have few boundary surfaces set as "empty", but your domain is not one cell thick. You will have to change the "empty" to something else like "wall". Also, try to use the search feature of this forum, since there are many people that encountered the same problem. I hope this is helpful, Dragos |
Hello Dragos,
first of all
Hello Dragos,
first of all thank you very much for your reply. I followed your approach and changed the empty boundary surfaces to wall. Unfortunately it seems that the changes didn't have an effect. InterDyMFoam still refined my mesh in 3D. I have a really simple mesh. See my blockMeshDict: vertices ( ( 0 0 0 ) ( 2 0 0 ) ( 2 4 0 ) ( 0 4 0 ) ( 0 0 1 ) ( 2 0 1 ) ( 2 4 1 ) ( 0 4 1 ) ); blocks ( hex ( 0 1 2 3 4 5 6 7 ) ( 16 32 1 ) simpleGrading ( 1 1 1 ) ); edges ( ); patches ( wall leftWall ( ( 0 3 7 4 ) ) wall rightWall ( ( 1 2 6 5 ) ) wall lowerWall ( ( 0 4 5 1 ) ) wall emptyWalls ( ( 0 1 2 3 ) ( 4 5 6 7 ) ) patch atmosphere ( ( 3 2 6 7 ) ) ); mergePatchPairs ( ); At the 0 directory I have changed the patch emptyWall as follows : gamma -> zeroGradient, pd -> zeroGradient, U -> fixedValue, value ( 0 0 0 ). After a few seconds of simulation InterDyMFoam still refined the mesh in 3D, also at walls with one cell thickness. How can I do it, that InterDyMFoam just refines the mesh in 2D? And not 3D! (Cmp. the pictures below). I also used the search of the OpenFOAM forum but I did not find something that helped on! Any hints are welcome! Thanks, Ala Mesh before: http://www.cfd-online.com/OpenFOAM_D...your_image.gif and the mesh afterwards: http://www.cfd-online.com/OpenFOAM_D...your_image.gif |
Sorry, there was an error whil
Sorry, there was an error while uploading the pictures from my last post. Here are the two pictures:
Mesh before: http://www.cfd-online.com/OpenFOAM_D...es/1/10908.jpg and the mesh afterwards: http://www.cfd-online.com/OpenFOAM_D...es/1/10909.jpg |
Hi Ala,
The dynamic mesh cl
Hi Ala,
The dynamic mesh class used in interDyMFoam handles only refinement in 3D. When a hexahedron is refined, it is split in eight. Always. Note that the same hex splitter is used in the snappyHexMesh mesh generator, which consequently will always give you a 3D mesh. To make the dynamic mesh class refine/coarsen in 2D, someone would have to develop a new algorithm which does the cell and edge splitting only in two directions. That is certainly possible, but I have not heard of anyone spending time on it. I think it takes quite some experience and knowledge to do it. And time. Or finance Icon or OpenCFD to do it. Depending on what you want to do, you might look at the (older?) approach of the refineMesh utility. It works in 2D as well, but it is not meant to run during the simulation. Maybe you could hack a solver of your own to do the refinement action between time steps, but I don't think this is a trivial task, either. Good luck! Ola |
2D mesh refinement
Hi All,
Has this issue been resolved by someone? I would also like to be able to run Dynamic mesh refinement in a 2D case. Please let me know if anyone has been able to accomplish this. Regards Luther |
empty to symmetry
Hi
i also face the same problem . so i set the empty to symmetry plane. wayne |
hi Wayne,
Thank you. Will try it. Do you perhaps know what the implications is on computation time changing empty to symmetry? Regards Luther |
I am sorry i don`t..i try this for we do 2D case in CFX is setting this face to symmetry and i think it will restrict something.but it also split the mesh in these direction
Problem with dynamicRefineFvMesh
I am also trying to employ the dynamic mesh refinement tool. It works fine for any mesh generated by blockMesh; whenever I try to run a case whose mesh was created by snappyHM I get the following error: Only call if constructed with history capability#0 Foam::error::printStack(Foam::Ostream&) in "/home/brunno/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/brunno/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::hexRef8::getSplitPoints() const in "/home/brunno/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicMesh.so" #3 Foam::dynamicRefineFvMesh::selectUnrefinePoints(do uble, Foam::PackedList<1u> const&, Foam::Field<double> const&) const in "/home/brunno/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicFvMesh.so" #4 Foam::dynamicRefineFvMesh::update() in "/home/brunno/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libdynamicFvMesh.so" #5 main in "/home/brunno/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/interDyMFoam" #6 __libc_start_main in "/lib/libc.so.6" #7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function hexRef8::getSplitPoints() in file polyTopoChange/polyTopoChange/hexRef8.C at line 4873. FOAM aborting Aborted Has anyone faced this problem before ? |
Hi at all,
I'm also looking for dynamicrefineMesh for 2D! Does anybody have a solution for this? I tried to understand the code but its dufficult for me.... Thanks a lot in advance! Victor |
I know that this is quite old but for others I recommend this paper regarding 2D local dynamic mesh refinement. http://digitalcommons.mtu.edu/cgi/vi...8&context=etds It describes the idea and gives example implementation in OpenFOAM. |
