I am relatively new to
I am relatively new to OpenFoam, I am trying to solve coupled equations using my own solver. I am getting the following error. What does this mean? Kindly give your suggestions as what I should do to solve the problem. I am using relaxation technique to solve the coupled problem. #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7f3d420] #3 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/vishal/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so" #5 main in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/coupledFoam" #6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #7 Foam::regIOobject::readIfModified() in "/home/vishal/OpenFOAM/vishal-1.5/applications/bin/linuxGccDPOpt/coupledFoam" Floating point exception Kindly do the needful help. Thanks Regards Vishal |
Give a look here, http://openf
