Home > Forums > OpenFOAM Running, Solving & CFD
Combine several dynamic mesh options
Old   October 9, 2008, 11:42
Default Hi, I know there are manty
Daniel Schmode
daniels is on a distinguished road
I know there are manty thread on mesh motion, but I guess non does fit this one...
I used interDyMfoam with the solidBodyMotionFvMesh and the dynamicRefineFvMesh. Aseptically the second is great!!! Now I would like to use both features together to do adaptive meshing in a moving (but solid) mesh. What is the easiest way. Do I have to combine both options hardwired by creating a new library? Or is it possible to combine them via run time selection? If yes, how to setup in dynamicMeshDict?
Thanks
Daniel
daniels is offline   Reply With Quote
Old   January 28, 2009, 12:59
Default Hi, recently I observed the
Daniel Schmode
recently I observed the same problem. Find attached a case free surface testcase (derived from icoDyMFoam's the movingCone) an an animation showing the results.
The lower plots in the included animation shows the MULES result. Ggamma is exeding one, if the cell volume is decreasing due to mesh deformation. Gamma is unphysically reduced if cell volume is increasing.
I used solidBody motionMesh (constant cell volume) without this problems.
I tracked the error down to MULES. Find attached a simplified interDyMFoam, which uses (insead of MULES) a simple scalar transport equation for gamma (in gammEqn2.H). The result is plotted in the bottom plot of the attached animation.
MULES interface compression feature is higly desirable, thus I would like to use MULES in combination with movingMesh.
So, can anybody help me undersantding or repatring MULEs for moving mesh?
Thaks
Daniel
Old   January 28, 2009, 13:03
Default Here comes the attachment (hop
Daniel Schmode
Here comes the attachment (hopefully)...
movingGridFSproblem.tgz
Daniel
Old   January 28, 2009, 13:27
Default And here comes the animation.
Daniel Schmode
And here comes the animation. Mind the color map.
Sorry for the confusion, I am not yet very skilled using this forum software.
Daniel
Thread Tools
Trackbacks are On
Is it possible to combine results? wong FLUENT 0 September 28, 2008 12:18
how to combine two flow jai FLUENT 0 March 22, 2008 04:02
How to combine two meshes hsieh OpenFOAM Mesh Utilities 1 March 16, 2006 11:43
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 02:18
DPM and free surface: how to combine? Easycad FLUENT 1 November 2, 2003 15:17
