Problems with Unsteady simulations using LRR Model in transientSimpleFoam
Old   July 24, 2009, 05:51
Default Problems with Unsteady simulations using LRR Model in transientSimpleFoam
Barath Ezhilan
barath.ezhilan is on a distinguished road
Hi All,
I am trying to run Unsteady simulations using LRR model. I have followed the steps mentioned by Jasak here
(This was for SimpleFoam)
ie) Running k-epsilon for the first 100 iterations, calculate reynolds stress using R function and changing it to LRR
I am getting the following error
Create time
Create mesh for time = 0.0175
Reading field p
Reading field U
profile1DRawData:: Reading file : "/mnt/fs2/home/ebarath/project/jgrupp/SST_GAMG/unsteady/LRR/Netz9_improvement/constant/messein_Drall30_OF.csv" in turboCSV format
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model LRR
interpolateCoord not recognized: ""
From function profile1DfixedValueFvPatchField<Type>:rofile1Dfi xedValueFvPatchField(const fvPatch& p, const DimensionedField<Type, volMesh>& iF, const dictionary& dict)
in file finiteVolume/fields/fvPatchFields/derived/profile1DfixedValue/profile1DfixedValueFvPatchField.C at line 189.
FOAM aborting
Can anyone tell me what the problem is??
barath.ezhilan is offline   Reply With Quote
Old   July 25, 2009, 13:58
Default Found out the problem
Barath Ezhilan
The problem was actually with the R file generated for the last k-e timestep!
A slight modification yields the results!!!
non-linear k-epsilon model implementation problems Saidi Main CFD Forum 2 March 4, 2010 13:23
Unsteady Simulations of Phase Change Mike FLUENT 0 September 26, 2002 05:30
Model and Mesh generation Problems Anindya Main CFD Forum 1 May 19, 2001 02:02
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
k-omega model and unsteady transition Jens Thurso Main CFD Forum 1 May 4, 1999 09:50
