-   -   RhoSimpleFoam tutorial test case system dictionaries (http://www.cfd-online.com/Forums/openfoam-solving/58088-rhosimplefoam-tutorial-test-case-system-dictionaries.html)
flavio_pergolesi January 18, 2009 13:30
Hi all. I'm having some tro
Hi all.
I'm having some troubles in the attempt to run successful simulations with rhoSimpleFoam. It would be of great help to have a tutorial case (unfortunately rhoSimpleFoam is one of the standard solvers for whom is not provided an official tutorial), or even to have a look at how a more experienced user has set the dictionaries fvSchemes and fvSolution.
Using the search utility I found out some other (quite old) threads in which it was asked for something similar, so I guess that if someone manages to provide help that would be useful for several people.
Thanks in advance,
Flavio
aseroberto April 30, 2010 18:17
rhoSimpleFoam
http://www.cfd-online.com/Forums/ope...am-solver.html
I used his files as a starting ground and had to do some simple editing from there. Hope this helps.
mohammad_kordo April 17, 2014 08:41
one tutorial for rhoSimpleFoam
hi
you can find one tutorial for rhoSimpleFoam at below address:
https://github.com/OpenFOAM/OpenFOAM...icitFixedCoeff
also other tutorials is available here
best regards
