January 12, 2009, 17:57 |
Hallo everybody,
Hoping you
Hai Yu
Rep Power: 17 |
Hallo everybody,
Hoping you have had a good new years day, but I am facing a new problem. (^0^) I made a geography and mesh by Gambit (2D), as shown below. The structure is based on my own understanding of the requirement of icoDyMFoam, I am still not sure about whether it is right or wrong. I devided the region inside to two parts, one around a two-blade turbo, it contains the moving cells; and one on outside, it contains the stative cells. For the project, air flow from left to right, and the turbo rotates. I converted the mesh to Foam format, and edited it, then run icoDyMFoam, then the error message shows: Create dynamic mesh for time = 0 Selecting dynamicFvMesh mixerFvMesh --> FOAM FATAL ERROR : Error in face ordering: mixed used and unused faces at the end of face list. Number of used faces: 5219 and face 5219 is owned by cell 0 From function void polyMesh::initMesh() in file meshes/polyMesh/polyMeshCalcFaceCells.C at line 107. FOAM aborting (In the mesh, totally 12031 faces, 6812 are for frontAndBackPlanes, 5219 are for faces used to seperate cells.) Has anybody any idea on how this is about? And I have still another question: in the example of mixer2D, file "cellZones" contains only movingCells. So, how will Foam find out the stative cells and deal with them? Thx in advance. |
January 12, 2009, 17:59 |
can anybody tell me how to upl
Hai Yu
Rep Power: 17 |
can anybody tell me how to upload a picture?
January 13, 2009, 04:40 |
according to the website :
ht
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
Rep Power: 17 |
http://www.cfd-online.com/cgi-bin/Op...?pg=formatting \image{Text description} if it doesn't work you can upload the picture on a website like this one : http://www.imagup.com/index.php?page=upload and then put the link |
January 13, 2009, 11:42 |
This is a picture of me: http:
Hai Yu
Rep Power: 17 |
January 13, 2009, 17:45 |
Really? That is you?
(I apo
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
(I apologize for the cheap joke)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
January 14, 2009, 14:57 |
hallo, Bernhard, and all,
tha
Hai Yu
Rep Power: 17 |
thanks, florian I made some modifications, and now the problem changed to: ____________________________________ --> FOAM FATAL ERROR : Zero length edge detected. Probable projection error: slave patch probably does not project onto master. Please switch on enriched patch debug for more info From function void enrichedPatch::calcCutFaces() const in file slidingInterface/enrichedPatch/enrichedPatchCutFaces.C at line 248. ______________________ can anybody give some hints about this? |
Mesh Problem with icoDyMFoam | yuhai | OpenFOAM Running, Solving & CFD | 0 | January 12, 2009 17:53 |
Problem with icoDyMFoam | olivier | OpenFOAM Running, Solving & CFD | 13 | December 19, 2008 09:03 |
Problem with icoDyMFoam tutorial | matlie | OpenFOAM Bugs | 10 | April 26, 2007 04:51 |
Problem starting with icoDyMFoam | kassiotis | OpenFOAM Running, Solving & CFD | 1 | March 12, 2007 11:12 |
Problem with icoDyMFoam | philippose | OpenFOAM Running, Solving & CFD | 19 | March 7, 2007 12:06 |
