How to add transport equations
Old   January 8, 2009, 17:16
Default Hi guys I am trying to simu
Ali Mansouri
alimansouri is on a distinguished road
Hi guys
I am trying to simulate a simple mixing problem,
2D, single phase, turbulent and mixing in cross flow jets...
how can I add two species equations? should I use turboFoam ?
is there any tutorial etc ?
thank you!
Ali.
alimansouri is offline   Reply With Quote
Old   January 9, 2009, 05:37
Default Hi Ali, here's a simple exa
Ville Tossavainen
villet is on a distinguished road
Hi Ali,
here's a simple example how to add a (passive) scalar to an existing solver:
http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam
The example is for laminar solver, but in the similar way you can start from turbulent flow solver. "simpleFoam" is for steady-state problems and "turbFoam" for transient problems.
Hope this helps!
Ville
villet is offline   Reply With Quote
Old   January 9, 2009, 17:05
Default thanks Ville! have you see
Ali Mansouri
thanks Ville!
have you seen any tutorial in this area ?
Ali.
Old   January 11, 2009, 07:33
Default At the end of the wiki webpage
Ville Tossavainen
At the end of the wiki webpage there is a case file for the cavity flow case. But once you have created the solver, most of the work is done. Then you can just apply it to your case.
Or if you insist to have a simpler case, you can first modify icoFoam elbow mixing tutorial for one passive scalar.
Old   January 12, 2009, 15:00
Default Hi Ville If I would like to
Ali Mansouri
Hi Ville
If I would like to have two passive scalars, then should I add two equations ?
since in Fluent you add only one and the second one its just decuction from the whole field (e.g. concentration).
do you also have any idea about this error
Foam Fatal error" attempt to read beyond EOF"
thanks alot!
Old   January 12, 2009, 15:46
Default Yes, that's correct. Two equat
Ville Tossavainen
Yes, that's correct. Two equations for two passive scalars. Twice as much to write
I'm not sure what you mean about Fluent? Practically you can do the same thing with Fluent and OpenFOAM.
The last error... check your code if you're missing any closing parenthesis or ";".
Good luck with foaming!
Old   January 12, 2009, 16:20
Default Hi Ali! What you're talking
Assistant Moderator
Bernhard Gschaider
Hi Ali!
What you're talking about ("in Fluent") is the case that for the two scalars the relation s1+s2==1 is always true (because there are no other species)?
In that case you can always solve for s1 and then calculate s2=1-s1
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
How to solver coupled transport equations chris1980 OpenFOAM Running, Solving & CFD 8 October 29, 2019 07:15
Convergence of turbulence transport equations KK CFX 0 January 31, 2008 20:46
Under-Relaxation of Transport Equations Florian Fruth CFX 6 July 16, 2007 08:59
Scalar Transport Equations David harvey FLUENT 1 January 31, 2004 06:15
Scalar Transport Equations 123 Main CFD Forum 6 August 10, 1998 09:05
