-   -   A question of starting computation from an acquired result (http://www.cfd-online.com/Forums/openfoam-solving/58140-question-starting-computation-acquired-result.html)
jennyrui2008 January 8, 2009 22:38
I run "simpleFoam" solver to c
I run "simpleFoam" solver to calculate a flow field to step 600. Then I changed the discretization scheme for div(phi, U) from "upwind" to "QUICK". Then I modified "startFrom" entry as "startTime" and set "startTime" as "600" in the "controldict" file, and run "simpleFoam" again. But the following error message appeared as follows:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
Exec : simpleFoam
Date : Jan 09 2009
Time : 10:41:38
Host : ff02
PID : 4581
Case : /home/jiarui/OpenFOAM/jiarui-1.5/run/UCUF04K_Re16000/CellNo_595026_KOmega_simple Foam_From600
nProcs : 1
Create time
Create mesh for time = 600
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASMode ls.so"
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::tmp<foam::geometricfield<double,> > const&) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASMode ls.so"
#6 Foam::incompressible::RASModels::kOmegaSST::F2() const in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASMode ls.so"
#7 Foam::incompressible::RASModels::kOmegaSST::kOmega SST(Foam::GeometricField<foam: :vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASMode ls.so"
#8 Foam::incompressible::RASModel::adddictionaryConst ructorToTable<foam::incompress ible::rasmodels::komegasst>::New(Foam::GeometricFi eld<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASMode ls.so"
#9 Foam::incompressible::RASModel::New(Foam::Geometri cField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::transportModel&) in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libincompressibleRASMode ls.so"
#10 main in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/simpleFoam"
#11 __libc_start_main in "/lib64/libc.so.6"
#12 Foam::regIOobject::readIfModified() in "/home/jiarui/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/simpleFoam"
Can anyone help me out? Thanks in advance!!!
