Strange boundaries for k and epsilon
Old   December 16, 2008, 08:55
Default Hi, I have a pipe looking l
Henning Wilhelmi
henning is on a distinguished road
I have a pipe looking like this:
and its extruded along the flow direction (z-axis).
When I run simpleFoam (3000 Steps) I get unrealistic values for k(at least 184 though u = 3.725 m/s). Also near the boundaries they look strange. k should go back to 0 and epsilon should rise constantly.
I made a simpler case with a 2D channel and a similar mesh. Here the results look quite good.
Any idea what i am doing wrong?
B.c.s for k and epsilon are zeroGradient (similar to the tutorial cases in simpleFoam / turbFoam) and just for the internal field I gave values. I also tried values on inlet but then I get an error message saying I need zeroGradient at inlet patch.
Thanks for your help
Henning
henning is offline   Reply With Quote
Old   December 16, 2008, 10:24
Default what turbulence model do you u
Pierre Le Fur
pierre is on a distinguished road
what turbulence model do you use?
Have you had a look at boundaryFoam and its tutorial? Even channelOodles. That might help.
Pierre
pierre is offline   Reply With Quote
Old   December 16, 2008, 14:10
Default Why don't you try a different
Juan Fernando Duque Lombana.
juanduque is on a distinguished road
Why don't you try a different mesh configuration, check O-Grid configuration, that might help.
juanduque is offline   Reply With Quote
Old   December 17, 2008, 05:07
Default I am using the classical k-eps
Henning Wilhelmi
I am using the classical k-epsilon model.
I took a look on boundaryFoam. It uses zeroGradient b.c. for both, k and epsilon as well. channelOodles didn't help me that much since it is LES and i am not so familar with LES.
And changing the mesh ... well, I don't like to use O-Grid for this solution since I would prefer a mesh that can be made finer at the boundaries easyly.
Maybe any other ideas?
Anyhow, thank you very very much for your help so far.
Henning
Old   January 7, 2009, 02:54
Default Well, found my problem. Did pa
Henning Wilhelmi
Well, found my problem. Did patch instead of wall in blockMeshDict. It's always the simple things that make life so interesting ;)
Strange boundaries for k and epsilon henning OpenFOAM Running, Solving & CFD 0 December 16, 2008 08:42
Strange boundaries for k and epsilon henning OpenFOAM Running, Solving & CFD 0 December 16, 2008 08:34
derivation of epsilon equation of k-epsilon model Ricardo Rezende Main CFD Forum 5 May 1, 2007 05:38
Strange epsilon chris1980 OpenFOAM Running, Solving & CFD 6 October 24, 2006 09:05
k and epsilon on inlet boundaries Daniel Siemens 3 February 12, 2002 10:45
