Error size 400 is not equal to the given value of 1681 |
December 31, 2008, 15:04 |
Hi guys
I am working on my
Ali Mansouri
Hi guys
I am working on my first tutorial (lidcavity) and I changed the mesh density from 20*20 to 41*41 and I got this error size 400 is not equal to the given value of 1681 could you help and let me know what I am missing? thank you! |
January 6, 2009, 06:32 |
Hi ,
I m not sure just delete
Sachin Kanetkar
Hi ,
I m not sure just delete all other files other than blockMeshdict from polyMesh folder and again run blockMesh... i hope u ran blockMesh command after editing meshdict |
January 7, 2009, 04:58 |
The initialization of gamma is
Sebastian Gatzka
Rep Power: 20 |
The initialization of gamma is done in a list containing 20*20 values. If you change the cell to 41*41 there are more cells than values for gamma.
You have to set the gamma field to the new mesh using setFields or funkySetFields. Tell me if this works out.
Schrödingers wife: "What did you do to the cat? It's half dead!" |
December 2, 2009, 06:40 |
Claus Meister
Thanks a lot!
It had worked. cheers |
August 6, 2018, 01:12 |
Ainal Hoque Gazi
Rep Power: 7 |
Hi sir i am facing same error in twoPhaseEulerFoam.how did you solve your problem ?please help. i am very new in openfoam. where to change gamma value i am not able to find out.i am using openFoam 5.0. ....size 6000 is not equal to the given value of 49600 Thanks and please reply . |
August 6, 2018, 05:08 |
Robert
Rep Power: 11 |
As Sebastian wrote in 2009, your gamma file contains less values than you have grid points. This is most likely because you changed the mesh of the case that you are using. Create a "empty" gamma file in your 0 folder. Similar to the other variables there, with only your boundaries. If you need a patch value or internal field, define it there. But dont use the gamma file with a list of values that dont match your mesh.
Alternatively, you can try mapping the lower resolution list onto your new mesh using map fields.
If you liked my answer to your question, please consider leaving a "Like" in return |
August 6, 2018, 09:19 |
#7 | |
Ainal Hoque Gazi
Rep Power: 7 |
Thank you very much sir, for your quick reply.As i said i am very new in openFoam.Will you please give me a example. after making gamma file and putting my boundary condition what will be the gamma value??sorry for my little knowledge. Regard |
August 7, 2018, 03:16 |
#8 | |
Robert
Rep Power: 11 |
FoamFile { version 2.0; format ascii; class volVectorField; location "686"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField nonuniform List<vector> 40707 ( (5.75351e-08 1.78608e-13 -1.29983e-08) (4.34756e-08 -1.68768e-11 1.1458e-08) (6.87797e-08 -1.31685e-11 -1.64066e-08) (1.26222e-07 1.20794e-11 -2.15262e-09) (8.19207e-08 6.92902e-12 1.65675e-08) (3.25676e-08 -2.42031e-11 -9.9565e-10) (3.88896e-07 -1.56001e-11 3.71109e-08) (3.39852e-07 7.24725e-12 1.21746e-08) (3.42452e-07 1.10985e-11 7.22658e-09) [...] (1.25084e-06 -1.60452e-10 1.37135e-09) (1.16599e-06 6.83278e-11 -6.65523e-09) (1.25118e-06 1.34288e-10 1.54835e-09) (1.16659e-06 -2.39878e-11 2.30208e-09) ) ; boundaryField { front { type slip; } back { type slip; } inlet { type fixedValue; value nonuniform List<vector> 92 ( (3.9921e-07 9.41269e-12 3.60087e-08) (9.47981e-07 -1.95452e-12 4.31057e-08) (1.35416e-06 -1.04229e-11 3.00812e-08) [...] (1.16941e-06 -5.50304e-11 4.28134e-08) (1.2247e-06 -3.0136e-10 4.27937e-08) ); } outlet { type inletOutlet; inletValue uniform (0 0 0); value nonuniform List<vector> 74 ( (4.53798e-07 -2.58165e-10 4.07981e-08) (9.47981e-07 -1.95452e-12 4.31057e-08) [...] (1.58258e-06 -1.05756e-14 4.61522e-09) (1.05566e-06 2.77257e-11 4.06847e-08) (1.05562e-06 5.70094e-11 4.06854e-08) (9.4798e-07 7.00389e-12 4.30221e-08) ); } top { type slip; } lowerWall { type fixedValue; value uniform (0 0 0); } } Code:
FoamFile { version 2.0; format ascii; class volVectorField; location "1"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.000625 0 0); boundaryField { bottom { type fixedValue; value uniform (0 0 0); } top { type slip; } inlet { type cyclic; } outlet { type cyclic; } front { type slip; } back { type slip; } lowerWall { type fixedValue; value uniform (0 0 0); } } If you need further help,dont hesitate to ask, but provide more detail. For example post the error OpenFoam gives you. Or post the file that gives your problems.
August 7, 2018, 07:26 |
#9 | |
Ainal Hoque Gazi
Rep Power: 7 |
I got it, the error has gone now.Thank you very much for your detail explanation,I really appreciate. |
FOAM FATAL IO ERROR size 1 is not equal to the given value of 26776 | hariya03 | OpenFOAM Pre-Processing | 3 | June 14, 2013 02:11 |
Strange results from interFoam solution converges but sum of all forces not equal to zero | nicasch | OpenFOAM Running, Solving & CFD | 0 | April 15, 2008 02:01 |
[blockMesh] BlockMesh error with growing mesh size | kian | OpenFOAM Meshing & Mesh Conversion | 4 | September 24, 2007 16:00 |
Error while using size function(urgent!) | Neo | FLUENT | 0 | June 16, 2007 12:24 |
Error: insufficient catalogue size | Anurag | CFX | 1 | January 7, 2005 09:01 |
