moveDynamicMesh with dynamicMotionSolverFvMesh |
March 16, 2012, 14:32 |
Rep Power: 16 |
I want to use moveDynamicMesh to give initial conditions (rotation, for example) of a floating object (taken from the interDyMFoam tutorial). I then want to solve for the motion using dynamicMotionSolverFvMesh tools. I have been able to use moveDynamicMesh in combination with solidBodyMotionFvMesh, but I am not sure how to go about using it in the case of a deforming mesh. Any hints? Thanks |
May 16, 2012, 05:40 |
Samuele Z
Rep Power: 18 |
Have you reached your goals? Are you still working on this problem?
Thanks a lot, Samuele |
May 16, 2012, 18:33 |
Rep Power: 16 |
Hi Samuele,
Yes, I figured it out. A sample dynamicMeshDict would look like: Code:
*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object motionProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicMotionSolverFvMesh; twoDMotion yes; //optional motionSolverLibs ("libfvMotionSolvers.so"); solver displacementSBRStress; diffusivity quadratic inverseDistance 1(wall); ************************************************************************* // Code:
FoamFile { version 2.0; format ascii; class pointVectorField; location "0.01"; object pointDisplacement; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { side1 { type fixedValue; value uniform (0 0 0); } side2 { type fixedValue; value uniform (0 0 0); } top { type fixedValue; value uniform (0 0 0); } bottom { type fixedValue; value uniform (0 0 0); } wall { type angularOscillatingDisplacement; value uniform (0 0 0); axis (0 0 1); origin (0 0 0); angle0 0; amplitude 0.262; omega 1.57; } } I hope this helps. Greg |
May 17, 2012, 05:12 |
Samuele Z
Rep Power: 18 |
Hi Greg and thanks a lot for answering.
I have one more (slightly different) question: if I would like to perform a simulation on a moving geometry (i.e. an opening door), is it possibile to create 10 meshes (each one created with a mesh generator) and study the solution on those meshes? If so, the point is: how can I assign the solution at time step n to the initial guess of the step (n+1)? Thanks a lot, Samuele |
May 17, 2012, 09:34 |
Rep Power: 16 |
I'm not sure if I am understanding your question. You would like to take the solution at some time n from one of your 10 meshes and make that an initial condition for the next mesh? If thats the case, then you can use mapFields to do this, which essentially takes the field data and interpolates it onto a different grid. The closer the two grids are to each other, the better of course.
June 14, 2012, 06:25 |
Samuele Z
Rep Power: 18 |
Dear Greg,
thanks for answering. One more question: could you explain the meanings of these entries Code:
wall { type angularOscillatingDisplacement; value uniform (0 0 0); axis (0 0 1); origin (0 0 0); angle0 0; amplitude 0.262; omega 1.57; } please? Thanks a lot, Samuele |
June 27, 2012, 05:32 |
Samuele Z
Rep Power: 18 |
Dear Philipp, Dear All,
something very strange happens. I am working on a dynamic mesh. All the dictionary I set, work very well for a certain geometry, but they don't for another one (of course I've edited the patch names). I can share my case if someone is interested and would like to help me. Thanks, Samuele |
March 19, 2014, 06:35 |
how to define 6DOF motion in the motionProperties
luchen
Rep Power: 14 |
hello,gfilip and samiam1000 , I am studying how to define the 6DOF mition in the motionProperties. I can use the interDyMFoam solver to solve two phase simulations. For more than three phase simluation, I have to take another solver multiphaseInterFoam. I want to input the 6DoF motion into the "motionProperties "file. Do you know how to do it? Thank you
Display Modes | |
moveDynamicMesh for moving a patch (Tz and Ry) | bouclette | OpenFOAM | 3 | August 26, 2013 16:59 |
moveDynamicMesh | Sylvain | OpenFOAM | 13 | November 11, 2011 00:22 |
moveDynamicMesh in parallel chrashes | Arnoldinho | OpenFOAM Bugs | 18 | May 19, 2011 14:57 |
moveDynamicMesh broken ? | podallaire | OpenFOAM Bugs | 2 | November 11, 2009 14:44 |
