Heat transfer with solid elements conduction
Old   July 1, 2005, 12:58
Default Hi Henrry, I am trying the
  #21
shu
Bitan SHU
shu is on a distinguished road
Hi Henrry,
I am trying the first method that you mentioned on March 16, 2005, because in this way I don't need to transfer the boundary condition in every timestep. It works well with two different thermal conductivities for the thermal equation. In order to set the (no-slip) boundary condition on the interface for the fluid, I defined the interface as a boundary additionally. But this additional boundary is ignored during the computation. Is it not correct to take the interface as boundary? How can I do it correctly?
BTW, What do you mean with "... a face-zone for the solid interface to apply the correct drag onto the fluid"? How can I set up this "face-zone"?
Thanks in advance!
Bitan
shu is offline   Reply With Quote
Old   July 1, 2005, 13:40
Default Thanks Mattijs, but how to re
  #22
Daniele Panara
panara is on a distinguished road
Thanks Mattijs,
but how to read two meshes? I am a bit confused how to push the program to read the mesh from a different location than the default directory..
can you give me also an hint on how to handle the input output of the mesh?
I guess that I should modify the createMesh.H in order to have two mesh objects... but I am not sure how =(
Thanks in advance
Daniele
panara is offline   Reply With Quote
Old   July 1, 2005, 14:09
Default 1. create two different Time i
  #23
Mattijs Janssens
mattijs is on a distinguished road
1. create two different Time instances, say runTime1 and runTime2. Then separately load meshes:
fvMesh mesh1
IOobject
fvMesh::defaultRegion,
runTime1.timeName(),
runTime1,
IOobject::MUST_READ
and similar for mesh2.
2. or nicer: have one runTime with two mesh regions. Change the fvMesh::defaultRegion into "region1" and "region2" and put your meshes in
constant/region1/polyMesh and constant/region2/polyMesh
I have never tried this so good luck ;-)
mattijs is offline   Reply With Quote
Old   July 1, 2005, 15:20
Default I had a go at option 2. It is
  #24
Mattijs Janssens
I had a go at option 2. It is just two simpleFoams running in the same time loop. It is just an example of how to create two regions, the regions are not coupled!
simpleFoam-twoMeshes.tgz
Old   July 1, 2005, 15:43
Default Thanks very much!! that helps
  #25
Daniele Panara
Thanks very much!!
that helps me a lot in understanding the code!!
many thanks =)
Daniele
Old   July 5, 2005, 11:35
Default Dear all, I would like to i
  #26
Daniele Panara
Dear all,
I would like to implement an explicit coupling for conjugate heat transfer in open Foam.
I would like to solve the conductive equation in a region 1 and the NS equation in region2 and exchange the temperature BC in order to have
T1=T2 and
k1*grad(T1)=k2*grad(T2)
is that a good way for the couppling?
Can anybody suggest me an efficient way to do it in open Foam and/or bibliography on the subject?
Thanks in advance,
Daniele
Old   July 6, 2005, 08:48
Default Dear all, How is it possible
  #27
Daniele Panara
Dear all,
How is it possible to access and modify the value of a fixedGradient boundary condition?
I am asking because I would like to compute the gradient of the temperature in a region and use it as a boundary condition for the other region using a fixedGradient BC.
Is it possible?
Daniele
Old   July 6, 2005, 09:33
Default Daniele, I think you can se
  #28
Juergen Almanstoetter
almanstoetter is on a distinguished road
Daniele,
I think you can set the fixedGradient BC the following way:
if(TMesh1.boundaryField()[patchIMesh1].type() == "fixedGradient"){
fixedGradientFvPatchScalarField& bufferMesh1=
refCast<fixedgradientfvpatchscalarfield>(TMesh1.bo undaryField()[patchIMesh1]);
scalarField& gradMesh1 = bufferMesh1.gradient();
scalarField& patchlambdaFieldMesh1 = lambdaFieldMesh1.boundaryField()[patchIMesh1];
forAll (bufferMesh1, faceI)
gradMesh1[faceI] = ...
To couple two regions with different temperatures, a possibility would be to set the gradient from one side as a BC on the other side, calculate the temperature distribution and set the average between the new temperature for this boundary and the boundary on the other (old) side as a new boundary condition on the other side. Run the whole as an iterative process until the temperature difference between both sides is below a certain small value.
When you have finished your implementation could you please post it in here ? I think there are also other people interested in it.
Juergen
almanstoetter is offline   Reply With Quote
Old   July 6, 2005, 10:28
Default Thanks very much for your sugg
  #29
Daniele Panara
Thanks very much for your suggestion, and if I manage to finish this implementation I will post it for sure!!
The problem is that I am a new C++ programmer..
I tryed your suggestion and I got the following error message:
conjugateFoam.C:91: error: `fixedGradientFvPatchScalarField' undeclared (first use this function)
conjugateFoam.C:91: error: (Each undeclared identifier is reported only once for each function it appears in.)
conjugateFoam.C:91: error: `buffer' undeclared (first use this function)
conjugateFoam.C:91: error: `fixedGradientFvPatchScalarfield' undeclared (first use this function)
conjugateFoam.C:91: error: template argument 1 is invalid
conjugateFoam.C:91: error: no matching function for call to `refCast(Foam::fvPatchField<foam::scalar>&)
I know it is a stupid error due to some include things...
but when I tryed to include fixedGradientFvPatchField.H I got other terrible error messages...
Can anybody help me?
Daniele
Old   July 6, 2005, 11:34
Default What other error messages ? Is
  #30
What other error messages ? Is the file fixedGradientFvPatchField.H found by the compiler ?
Juergen
Old   July 6, 2005, 13:16
Default I am solving two laplacian foa
  #31
Daniele Panara
I am solving two laplacian foam in two different regions and I am trying to couple them.
I have modified the laplacian foam in order to handle two grid regions mesh1 and mesh2 and I am solving for T1 and T2.
(This is the file)
conjugateFoam.C
the program works fine without the following lines:
# include "fixedGradientFvPatchField.H"
refCast<fixedgradientfvpatchscalarfield>(T2.bounda ryField()[bottomReg2]);
whit the lines above instead I get the following error messages:
SOURCE_DIR=.
SOURCE=conjugateFoam.C ; g++ -m32 -Dlinux -Wall -W -Wno-unused-parameter -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -I/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-1.1/src/cfdTools/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxOpt/conjugateFoam.o
In file included from conjugateFoam.C:48:
/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.H: In function `int main(int, char**)':
/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.H:43: error: unknown namespace `<declaration>'
/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.H:42: error: expected primary-expression before "namespace"
/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.H:42: error: expected `;' before "namespace"
In file included from /opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.H:197,
/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.C:35: error: unknown namespace `<declaration>'
/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.C:34: error: expected primary-expression before "namespace"
/opt/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude/fixedGradientFvPatchField.C:34: error: expected `;' before "namespace"
conjugateFoam.C:91: error: `bufferMesh1' undeclared (first use this function)
conjugateFoam.C:92: error: `fixedgradientfvpatchscalarfield' undeclared (first use this function)
conjugateFoam.C:92: error: template argument 1 is invalid
conjugateFoam.C:92: error: no matching function for call to `refCast(Foam::fvPatchField<foam::scalar>&)'
make: *** [Make/linuxOpt/conjugateFoam.o] Error 1
I know it is a stupid mistake but anybody can help?
Thanks Daniele
Old   July 7, 2005, 04:54
Default Danielle, there are two err
  #32
Danielle,
there are two errors in your file:
1. Put the # include "fixedGradientFvPatchField.H" before the main() just right after the #include "fvCFD.H" to avoid the namespace errors.
2. There is a typo in your declaration of bufferMesh1. In the refCast<...> you use fixedgradientfvpatchscalarfield, but it should be fixedGradientFvPatchScalarField
Juergen
Old   July 7, 2005, 05:09
Default Thanks for your help, I apreci
  #33
Daniele Panara
Thanks for your help, I apreciate...
I tryed also correcting the errors you said but this is the output..
SOURCE_DIR=.
conjugateFoam.C: In function `int main(int, char**)':
conjugateFoam.C:92: error: `fixedGradientFvPatchScalarField' undeclared (first use this function)
conjugateFoam.C:92: error: (Each undeclared identifier is reported only once for each function it appears in.)
conjugateFoam.C:92: error: `buffer' undeclared (first use this function)
conjugateFoam.C:93: error: template argument 1 is invalid
conjugateFoam.C:93: error: no matching function for call to `refCast(Foam::fvPatchField<foam::scalar>&)'
May be I have to modify somehow the files in the Make directory?
at the moment I have in files the following:
conjugateFoam.C
EXE = $(FOAM_USER_APPBIN)/conjugateFoam
and in options:
EXE_INC = \
-I$(LIB_SRC)/cfdTools/lnInclude
EXE_LIBS = \
-lcfdTools
are them correct?
Thanks again, Daniele
Old   July 7, 2005, 05:36
Default Danielle, I have added some
  #34
Danielle,
I have added some of the missing *.H files nedded by your conjugateFoam.C and compiled it without errors. Here is the tgz-ball:
conjugateFoam.tgz
Juergen
Old   July 7, 2005, 06:31
Default You are right!! now it works!!
  #35
Daniele Panara
You are right!! now it works!! =)
I was including fixedGradienFvPatchField.H and not fixedGradientFvPatchFields.H !!!
Thanks again!! =)
Daniele
Old   July 7, 2005, 14:26
Default In the following I am attachin
  #36
Daniele Panara
In the following I am attaching the solver and the case I am working on.
The solver is not at all tested!!
The case I am working on is a 2D case consisting of two simple coupled long bar with
different conductivity as sketched below:
<blockquote><blockquote><blockquote><blockquote><b lockquote>fix T2
</blockquote></blockquote></blockquote></blockquote></blockquote>
<blockquote><blockquote>__________________________ _
no heat flux | region2 ( fixed conductivity DT2 ) | no heat flux
<blockquote><blockquote>-----------------------------------------
fix T for reg1 (from reg2), fix gradT for reg2 (from reg1)
no heat flux | region1 ( fixed conductivity DT1 ) | no heat flux
<blockquote><blockquote><blockquote><blockquote><b lockquote>fix T1
I run two laplacian foam for two different meshes (region1 and region2) and at the end of the time step I pass the Temperature at the boundary from region2 to region1 and the temperature gradient (scaled by the ratio of the conductivity DT1/DT2) from region1 to region2.
Or at list that is what I have tryed to do...
Any comment and/or suggestion is wellcome,
this is the solver:
conjugateFoam.tgz
this is the case:
conjugate2bars.tgz
Daniele
Old   July 14, 2005, 11:16
Default Hi Daniele how can I generat
  #37
olivier Petit
olivier is on a distinguished road
Hi Daniele
how can I generate the mesh in your case
blockMesh dont work !
thank you for your help
olivier is offline   Reply With Quote
Old   July 14, 2005, 11:38
Default you can create the two mesh se
  #38
Daniele Panara
you can create the two mesh separately copying the polymesh directory from region1/ (region2/) to its parent directory.
Then you can run block mesh and you can move back the polymesh directory in the region1/ (region2/) subdirectory.
Another way could be to modify blockmesh to read and write in the non default directory.. I did it but in a very hugly way that works for one region per time... when I will find the time to make it in a better way I will upload the new blockmesh program..
Daniele
Old   July 18, 2005, 23:06
Default Hi Daniele Can you tell me h
  #39
li
Hi Daniele
Can you tell me how to post process?
thank u
Old   July 27, 2005, 16:06
Default Hello everybody, i have a p
  #40
georg's Avatar
georg is on a distinguished road
Hello everybody,
i have a problem with laplacianFoam and hope somebody can help me.
I am trying to simulate heat transfer in a solid.
As boundary conditions there are three surfaces with fixed temperature. For the diffusivity of the used V2A - Steel i found 3.93e-6 [m^2/s].
In my simulation i find values of -1e2 to 1e34 for T!!! Where can be my mistake?
With kind regards!
georg is offline   Reply With Quote
heat conduction in solid - mismatch to exp. res. Ralf Schmidt FLUENT 1 December 9, 2008 08:34
Solid mesh for heat conduction Munni FLUENT 1 December 12, 2006 12:24
heat conduction in a solid francesco FLUENT 0 May 27, 2004 18:00
Heat conduction in a solid domain Rene CFX 0 October 20, 2003 03:33
Heat conduction in a solid domain S. Balasubramanyam CFX 10 October 14, 2003 08:57
