Home > Forums > OpenFOAM Running, Solving & CFD
Heat transfer with solid elements conduction
Old   April 7, 2008, 06:34
Default hi Niels, thanks for the help
  #121
davey david
suredross is on a distinguished road
hi Niels,
thanks for the help.it is one fluid per inlet and also i first run the case(successfully) in icoFoam with one fluid and this is a new dimension to the problem(2 different fluids).how can i ,therefore, modify my earlier source code to cater for these two different fluids?or i have to try a new solver (interfoam)completely?
thank you once again
suredross is offline   Reply With Quote
Old   April 7, 2008, 07:14
Default Hi Davey The easiest would
  #122
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Davey
The easiest would be to look at the damBreak case. Try to run it an see what happens. When you understand how you should set the boundary conditions etc, the apply your geometry and solve using the interFoam solver.
- Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   April 8, 2008, 06:51
Default Hi Neil, i am trying the damb
  #123
davey david
Hi Neil,
i am trying the dambreak case now but with no success.blockmesh gives me this warning :
From function polyMesh::polyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 577
Found 10 undefined faces in mesh; adding to default patch.
moreover i do not understand the gamma.org and pd files.i think there is a problem with the block faces or the blocks themselves but i am at a loss.i know it might be a bit stupid but i just cant seem to make it any better.any ideas?
and also isn't there any way i can modify my earlier source code to solve this extended case of mine?
thanks in advance
davey
Old   April 8, 2008, 07:21
Default Hi Davey I suggest that you
  #124
ngj
Hi Davey
I suggest that you read on from page 55 in the User Guide. It will take you trough the setup procedure of the damBreak case.
Gamma is the quantity which tells you whether it is phase 1 or phase 2 which is present in the considered volume. pd is the dynamic pressure.
From my point of view it is significantly easier to use any of the multiphase solvers in stead of modifying icoFoam as it is for one phase only.
- Niels
Old   April 8, 2008, 07:34
Default hi Neil, i have resolved damb
  #125
davey david
hi Neil,
i have resolved dambreak to run now.trying it on my case now.thanks for your concern.
davey
Old   April 9, 2008, 06:07
Default hi Neil, when i run the code
  #126
davey david
hi Neil,
when i run the code on my case i get the following error message:
#0 Foam::error::printStack(Foam:stream&) in "/home/cfd/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/cfd/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0x110420]
#3 Foam::Time::adjustDeltaT() in "/home/cfd/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::Time::setDeltaT(double) in "/home/cfd/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 main in "/home/cfd/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/jxnFoam"
#6 __libc_start_main in "/lib/libc.so.6"
#7 Foam::regIOobject::readIfModified() in "/home/cfd/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/jxnFoam"
Floating point exception
any ideas on how to turn this around?
thank you.
Old   April 9, 2008, 07:03
Default Hi No, but try to sent me y
  #127
ngj
Hi
No, but try to sent me your entire setup, and I will give it a look today or tomorrow.
- Niels
Old   April 9, 2008, 08:17
Default hi Niels, here are the files
  #128
davey david
hi Niels,
here are the files
case:
solver:
thank you
Old   April 9, 2008, 08:41
Default I cannot download the files. U
  #129
ngj
I cannot download the files. Use my email address from my profile.
/ Niels
Old   April 11, 2008, 04:30
Default i have sent them to your mail
  #130
davey david
i have sent them to your mail address.
thank you
Old   April 14, 2008, 07:23
Default hi, how can add a concentrati
  #131
davey david
hi,
how can add a concentration equation to the icofoam solver to cater for liquids(2) of different concentrations?
thanks
davey
Old   November 14, 2008, 04:41
Default Hallo to all,, I am using
  #132
emilianyassenov
Hallo to all,,
I am using the IcoFoam and I have added the T field on it.but I have
linear in heat flow...Is it possible to have parabolic heat flow in
icoFoam
can somebody help me..
Thanks
Emo
Old   November 14, 2008, 06:17
Default my T file look like like this.
  #133
emilianyassenov
my T file look like like this...
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 0;
boundaryField
fixedWalls
type cyclic;
inlet
type fixedValue;
value uniform 295;
outlet
type zeroGradient;
I want to have parabolic results...I am using icoFoam, my model is pipe..
help me...
Emo
Old   November 14, 2008, 06:24
Default I think icoFoam cannot manage
  #134
ep4
Pattyn Eric
ep4 is on a distinguished road
I think icoFoam cannot manage heat transfert. It doesn't solve any energy equation.
You define a T file but i think icoFoam just doesn't use it.
The haet transfer solvers are given in the User guide (U-84)
ep4 is offline   Reply With Quote
Old   November 14, 2008, 06:44
Default Hallo Eric, Thanks for answ
  #135
emilianyassenov
Hallo Eric,
Thanks for answer...I have include the transfer equation
this one
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
TEqn.solve();
BC T:
like this
FoamFile
version 2.0;
format ascii;
object T;
internalField uniform 295;
boundaryField
fixedWalls
type zeroGradient;
inlet
type fixedValue;
value uniform 295;
outlet
type zeroGradient;
it is pipe..I have now const. T and I want to have it in parabolic...
is it possible..
thanks again
Emo
Old   November 14, 2008, 06:58
Default In your T file, the air at the
  #136
ep4
Pattyn Eric
In your T file, the air at the inlet is at 295 K, but you don't have any other surface heated or at a different temperature.
In this case, there is no heat transfert. For example, you should impose a temperature or a heat flux on your fixedWall boundary.
Old   November 14, 2008, 07:12
Default hello Again Eric, I want ex
  #137
emilianyassenov
hello Again Eric,
I want exactly that in fixedWall but I don t know how to do it...my inlet is water..
Can you help me..
Thanks in advance
Emo
Old   November 14, 2008, 07:18
Default I don't understand your proble
  #138
ep4
Pattyn Eric
I don't understand your problem. Water or air, you can impose a temperature on the wall for example, no?
fixedWalls
type fixedValue;
value uniform 350;
The fact that you are using water is related to the constant/thermophysicalProperties file where you have to choose the right properties, models,.. See chapter 7 of the User Guide.
Old   November 14, 2008, 08:50
Default Hallo Eric, I am beginner..
  #139
emilianyassenov
Hallo Eric,
I am beginner...I want to use IcoFoam...I have meshed simple pipe and I want to see temperature increasing or distribution...I am working with water...parabolic form there must be increasing or decreasing of T.I have now constant T.
thats all...
thanks can you help me
really thanks
Emo
Old   November 14, 2008, 09:47
Default Hello, Someone give me the
  #140
emilianyassenov
Someone give me the idea which solver should I use for laminar flow(water) where I can see heat flux distribution on it...my shape is pipe
thanks in advance
Emo
Thread Tools
Trackbacks are On
heat conduction in solid - mismatch to exp. res. Ralf Schmidt FLUENT 1 December 9, 2008 09:34
Solid mesh for heat conduction Munni FLUENT 1 December 12, 2006 13:24
heat conduction in a solid francesco FLUENT 0 May 27, 2004 18:00
Heat conduction in a solid domain Rene CFX 0 October 20, 2003 03:33
Heat conduction in a solid domain S. Balasubramanyam CFX 10 October 14, 2003 08:57
