Access private data member
Like Tree2Likes
  • 1 Post By denyo
  • 1 Post By olesen
Old   December 17, 2008, 07:12
Default Hi everyone, Just a more '
Frank Bos
lr103476 is on a distinguished road
Hi everyone,
Just a more 'general' C++ programming question. What is the best way to access private data member used in i.e. dynamicBodyFvMesh from your application, i.e. icoDyMFoam.C ?
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   December 17, 2008, 09:08
Default Hi Frank, private data are
Daniel Conrad
denyo is on a distinguished road
Hi Frank,
private data are accessed via a public function, which returns the value of a private variable (by convention indicated with underscore: privateVariable_) or a reference (&privateVariable_) to it.
Look through any .H file to look up you possibilities to access private data using function declared as public memberfunctions.
dynamicBodyFvMesh is a meshtype and needed for the runTimeSelectionTable. Nevertheless it is derived from fvMesh. Goto src/finiteVolume/fvMesh.H to see your options.
best regards,
Daniel
Pascal_doran likes this.
denyo is offline   Reply With Quote
Old   December 18, 2008, 03:02
Default Hi Frank, Having seen your
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Hi Frank,
Having seen your talk in Milano, I suspect that you're probably okay with C++ per se, but for your current question:
if you need read-only access to a private member, just add a public const member to the header, eg.
const foo& bar() const
return bar_;
and let the OpenCFD guys know that you need read access to the data for whatever reason so they can add it to the header for everyone.
If you need write-access to the data member, you should either question if this is the correct approach at all, or if you actually need a derived class. If the latter is the case, it would be reasonable to provide a protected write-accessor so that your derived class can monkey with the data.
One important note, however: be careful about mixing const/non-const and private/public declarations for the same member signature. If a non-const member is declared private and a const member of the same name and signature is declared public, the compiler cannot tell which one is meant when compiling your application. A simplified explanation: the first compiler pass just takes the best signature, but doesn't bother to work out if const access would have sufficed and you'll get lots of compiler complaints.
Kummi likes this.
olesen is offline   Reply With Quote
Old   May 5, 2018, 21:44
chengan.wang
wangchengan2003 is on a distinguished road
Send a message via Skype™ to wangchengan2003
Hello olesen,
I want to use incident radiation 'G' in my solver, which is also a private data in 'fvDOM.H'.
In c++ code, it writes
Class fvDOM Declaration
class fvDOM
public radiationModel
// Private data
//- Incident radiation [W/m2]
volScalarField G_;
//- Const access to incident radiation field
inline const volScalarField& G() const;
In my solver, I use
radiation::fvDOM fvDOM(T);
const volScalarField& G = fvDOM.G();
in 'createFields.H'. Then I use G to calculate T in 'TEqn.H', such as
T=pow(G/(4*sigma),0.25);
Unfortunately, I found that T is always zero. That means I did not read the G value exactly.
Now I have no idea. If you could give me some help?
Best regards,
Chengan
wangchengan2003 is offline   Reply With Quote
question on data access in parallel computation wangrensong FLUENT 0 January 7, 2009 03:24
UDF Data Access Macro Woo Meng Wai FLUENT 0 November 6, 2007 20:23
UDF's to access Postprocess data ivor FLUENT 1 December 15, 2003 10:07
access to FIDAP-internal data from within a UDF II Ingo Meisel FLUENT 1 April 23, 2001 11:47
access to FIDAP-internal data from within a UDF Ingo Meisel FLUENT 0 April 17, 2001 11:58
