Home > Forums > OpenFOAM Running, Solving & CFD
OppositeCellFace how to use
Old   December 11, 2008, 04:49
Default Hi All, How can oppositeCel
Niklas Winkler
nikwin is on a distinguished road
Hi All,
How can oppositeCellFace.C found in the doxygen manual be used? I would like to find the face opposite to a known face on the boundary to be able to calculate snGrad for that face.
Thanks in advance
/NW
nikwin is offline   Reply With Quote
Old   December 12, 2008, 04:06
Default Please, anyone?
Niklas Winkler
Please, anyone?
Old   December 12, 2008, 06:32
Default Hi Niklas, why don't you us
kbr
Kerstin
kbr is on a distinguished road
Hi Niklas,
why don't you use
<name>.boundaryField()[patchID].snGrad()
where 'name' is the name of the field you need snGrad for and patchID is the ID of the patch which can be found using
patchID = mesh.boundaryMesh().findPatchID("name")
where name is the name of patch, e.g. inlet?
Or did I misunderstand you?
Kerstin
kbr is offline   Reply With Quote
Old   December 12, 2008, 09:05
Default Hi, Thanks for the reply!
Niklas Winkler
I've tried <name>.boundaryField()[patchID].snGrad(). The problem is that if the BC for PatchID is e.g. set to zeroGradient as in my case the answer it gives is only zero. And my aim is to check the actual boundary condition "value".
But, I found that the following line can be used to find the opposite face, a lot of trixing with doxygen,
faceList oppFace=mesh.cells()[cellI].opposingFaceLabel(c[i],mesh.faces());
Correct me if I'm wrong, please!
So, now snGrad on oppFace is needed!?
All the Best
/NW
Old   December 12, 2008, 09:25
Default Sorry, label or labelList not
Niklas Winkler
Sorry, label or labelList not faceList!
/NW
Old   December 12, 2008, 09:28
Default Hi Niklas, if you want to k
kbr
Kerstin
Hi Niklas,
if you want to know the value of the field at the boundary than try
scalarField valueOnPatch = <name>.boundaryField()[patchID];
for any scalar or
vectorField valueOnPatch = <name>.boundaryField()[patchID];
for any vector. Then you get a field containing the values of the variable "name" on patch with ID "patchID". I think using oppositeCellFace is not a good choice to compute snGrad. Think about using polyhedras! Which is the opposite face in that case? Have a look in "oppositeCellFace.C". There's a comment written concerning that problem.
By the way, snGrad for a zeroGradient-BC gives you "zero" and that's right beause snGrad is the surface normal gradient and setting BC to zeroGradient you define your surface normal gradient to be zero.
Kerstin
Thread Tools
Trackbacks are On
