Home > Forums > OpenFOAM Running, Solving & CFD
Modify dissipation equation
Old   December 5, 2008, 21:27
Default Hi, I am trying to modify t
Daniel Harlacher
harly is on a distinguished road
I am trying to modify the dissipation equation in the standard kEpsilon model.
The problem is the following:
The dissipation equation looks like this:
// Dissipation equation
tmp<fvscalarmatrix> epsEqn
fvm::ddt(epsilon_)
+ fvm::div(phi_, epsilon_)
- fvm::Sp(fvc::div(phi_), epsilon_)
- fvm::laplacian(DepsilonEff(), epsilon_)
C1_*G*epsilon_/k_
- fvm::Sp(C2_*epsilon_/k_, epsilon_)
Instead of C1 I want to put:
fvScalarMatrix C1star = C1_+C1_*0.38*k_/epsilon_*1.0/(Gstar)*fvm::ddt(Gstar);
but it complains - from my understanding the variable types are not compatible G looks like this:
volScalarField G = nut_*2*magSqr(symm(fvc::grad(U_)));
and Gstar:
volScalarField Gstar = 0.5*magSqr(U_)+k_;
Has anyone an idea how I can make them compatible ? - the problem was, that 'fvm::ddt(Gstar)' only works in a fvScalarMatrix for me.
thanks
- harly
harly is offline   Reply With Quote
Old   December 9, 2008, 10:07
Default Hi Harly! Have a look at th
Assistant Moderator
Bernhard Gschaider
Hi Harly!
Have a look at the programmers guide section 2.4 (especially page 36): in order to get a source term for another equation you have to use the explicit form of the differential operators (in your case that might be fvc::ddt)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Thread Tools
Trackbacks are On
Adding viscous dissipation term to energy equation newbee OpenFOAM Running, Solving & CFD 4 August 25, 2006 14:33
How to modify a value by a UDF? jwt FLUENT 3 May 23, 2003 12:01
how to modify model wang FLUENT 1 April 14, 2002 03:40
Modify the htc using UDF on NT frederic FLUENT 0 February 7, 2000 08:51
expansion of Hanjalic dissipation model of the RS equation Ehab Haj-Qasem Main CFD Forum 0 July 26, 1999 12:58
