Hey, I ran into a problem with
Hey, I ran into a problem with the interFoam solver. Whenever I remake (wmake) the solver after adding a couple of comments I get a warning saying: there is an 'unused variable' from the readPISOControls.H . So I copied the original interFoam solver and renamed it and ran wmake, and I get the same warning:
Making dependency list for source file test_interFoam.C SOURCE=test_interFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/transportModels -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/transportModels/incompressible/lnInclude -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/transportModels/interfaceProperties/lnInc lude -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/test_interFoam.o /usr/apps1/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/readPISOControls.H: In function ‘int main(int, char**)’: /usr/apps1/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/readPISOControls.H:3 : warning: unused variable ‘nCorr’ g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/transportModels -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/transportModels/incompressible/lnInclude -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/transportModels/interfaceProperties/lnInc lude -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/usr/apps1/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread Make/linuxGccDPOpt/test_interFoam.o -L/usr/apps1/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt \ -linterfaceProperties -lincompressibleTransportModels -lfiniteVolume -lOpenFOAM -ldl -lm -o /usr/erc/people/egehring/OpenFOAM/egehring-1.5/applications/bin/linuxGccDPOpt/te st_interFoam Is this just something I can ignore? Or is there something wrong with my interFoam solver? Thanks, feijo |
Hi Eelco,
it is just what i
Hi Eelco,
it is just what it says: A warning about an unused variable. Nothing to worry about. This happens if a variable is declared that is not used in the rest of the code. Best regards Christian |
Hi Eelco,
nCorr is unused
Hi Eelco,
nCorr is unused I have exactly the same warnig message Florian |
Hi Florian,
Thanks, i was w
Hi Florian,
Thanks, i was wondering which variables isn't used. Eelco |
isn't nCorr used in the PISO l
isn't nCorr used in the PISO loop in interFoam.C?
// --- PISO loop for (int corr=0; corr<nCorr; corr++) { #include "pEqn.H" } I also specify it in my fvSolution file. |
