Multiple Reference Frame
Old   June 25, 2007, 05:10
Default I have implemented (with the h
Gabriel Barroso
gabriel is on a distinguished road
I have implemented (with the help of you all) rotating wall boundary conditions and single reference frame for simpleFoam. Now i want to implement Multiple Reference Frame (rotor / stator). I don't need topological change, just one mesh is rotating and the other is static.
Thanks for your hints.
Bests Gabriel
gabriel is offline   Reply With Quote
Old   June 25, 2007, 05:50
Default Hello Gabriel, it's already i
Alberto Passalacqua
Hello Gabriel,
it's already implemented in OF 1.4. See OpenFOAM-1.4/tutorials/MRFSimpleFoam
Regards,
A.
Alberto Passalacqua
Old   June 26, 2007, 07:47
Default Sorry, thanks. I just looked i
Gabriel Barroso
Sorry, thanks. I just looked in FoamX.
Regards,
Gabriel
Old   February 7, 2008, 06:06
Default Hi, everyone! I've tried to r
Paul Mauk
plmauk is on a distinguished road
Hi, everyone!
I've tried to run tutorial-case MixerVessel2D (MRFSimpleFoam), but I've got an Error message
--> FOAM FATAL ERROR : cannot find MRF faceZone rotor
From function Foam::MRFZone::MRFZone(const fvMesh& , const dictionary&)
in file cfdTools/general/MRF/MRFZone.C at line 71.
FOAM exiting
thanks,
Paul.
plmauk is offline   Reply With Quote
Old   February 7, 2008, 08:22
Default Hi, I think you have to exe
Jason Dale
jason is on a distinguished road
I think you have to execute the mixerVessel2D\makeMesh script first. This builds the mesh and sets up the case before you can run it.
Regards
Jason
jason is offline   Reply With Quote
Old   February 12, 2008, 05:31
Default Hallo, the question may be qu
Paul Mauk
Hallo,
the question may be quite stupid, but how can I execute makeMesh-script?
I've tried allready simple double-click, but that does not lead to any positive results - MRF face Zone were not found...
Old   February 12, 2008, 05:42
Default I'M sorry, I ran setsToZones
Paul Mauk
I'M sorry,
I ran setsToZones .. mixerVessel2D -noFlipMap manually, and error message disapeared. But instead of that following mistake comes:
Starting time loop
Time = 1
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.0404075, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0403676, No Iterations 2
#0 Foam::error::printStack(Foam:stream&) in "/home/plmauk/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/plmauk/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0x110420]
#3 Foam::MRFZone::relativeFlux(Foam::GeometricField<d ouble,>&) const in "/home/plmauk/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::MRFZones::relativeFlux(Foam::GeometricField< double,>&) const in "/home/plmauk/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#5 main in "/home/plmauk/OpenFOAM/plmauk-1.4.1/applications/bin/linuxGccDPOpt/MRFSimpleFoam "
#6 __libc_start_main in "/lib/libc.so.6"
#7 Foam::regIOobject::readIfModified() in "/home/plmauk/OpenFOAM/plmauk-1.4.1/applications/bin/linuxGccDPOpt/MRFSimpleFoam "
Speicherzugriffsfehler
Have anybody an idea, what does it mean?
Old   February 12, 2008, 05:52
Default Hi Go to the mixerVessel2D
Jason Dale
Hi
Go to the mixerVessel2D directory and type
./makeMesh
it should then run through blockMesh etc automatically.
Then go up one directory and type
MRFSimpleFoam . mixerVessel2D
and it should work
Jason
Old   February 12, 2008, 06:05
Default Thank you very much, Jason, i
Paul Mauk
it works actually!
best regards,
Paul.
Old   February 12, 2008, 06:23
Default Great, One other thing, I d
Jason Dale
Great,
One other thing, I dont think you need the dynamicMeshDict file in the constant directory (left there by mistake?), you only need the MRFZones file which states the zone which is rotating, an origin point, the axis (at the origin point) which the rotation occurs around and the omega (i think its in rpm but Im not sure).
And I think its based on an incompressible solver so you need to multiply the calculated pressure by the density to get the real pressure in Pa.
Jason
Old   October 27, 2008, 12:07
Default Hello everyone, I want to s
  #11
Sebastian Vogl
sebastian_vogl is on a distinguished road
Hello everyone,
I want to simulate the aerodynamics of a car using MRFsimpleFoam. The car computer model is imported as .stl file. It was meshed with snappyHexMesh in OpenFoam 1.5 (that's why it must be an .stl file).
The reason why I post my problem here, is that I want to take into consideration the movement of the wheels of the car, as they have a great influence on the aerodynamics of the car. This can be generally done by using a multiple reference frame (MRF) boundary condition. For this reason I need MRFsimpleFoam.
My question is, how can I define the wheels of my .stl-car as patches which can be written in the MRFZones input file? Is there a possibility to get the names of the mesh elements which form the wheels and put them together to patches?
For your ideas I would be very grateful,
Yours
Sebastian Vogl
sebastian_vogl is offline   Reply With Quote
Old   October 29, 2008, 04:46
Default Dear Sebastian, Seems a bit
  #12
Gavin Tabor
grtabor is on a distinguished road
Dear Sebastian,
Seems a bit strange - surely all you need for the wheels is a moving wall, not a separate reference frame?
Gavin
grtabor is offline   Reply With Quote
Old   October 29, 2008, 12:05
Default Dear Gavin, thank you very
  #13
Sebastian Vogl
Dear Gavin,
thank you very much for your reply.
Meanwhile I could solve this problem on my own.
Yours,
Sebastian
Old   December 5, 2008, 07:27
Default Continuing this nicely named t
  #14
Niklas Wikstrom
wikstrom is on a distinguished road
Continuing this nicely named thread with another topic:
The MRF class reside in the "general" section of cfdTools. However, it seems to me that it must be modified for compressible or possibly multiphase codes. I mean, the relative flux in MRFZone.C is calculated as the volume swept by a face, whereas in the compressible case (rho!=1) where phi is massflux the relative flux should contain rho, right?
So, I have overloaded the MRFZone::relativeFlux function to allow const volScalarField& rho in the arguments and calculate phi as
phi[facei] -= rhof[facei] * ((Omega ^ (Cf[facei] - origin))) & Sf[facei];
However, the solver bails out (p-solver) after a number of iterations. (Hence this post.)
Am I wrong in my assumptions about compressible MRFZones?
cheers
Niklas
wikstrom is offline   Reply With Quote
Old   December 5, 2008, 09:30
Default Seems to work if the density i
  #15
Niklas Wikstrom
Seems to work if the density is considered in the application code instead for in the MRF. Using the volumetric relative flux from MRFZone I added density in pEqn.H of rhoSimpleFoam as follows:
surfaceScalarField phiv = fvc::interpolate(U) & mesh.Sf();
surfaceScalarField rhof = fvc::interpolate(rho);
mrfZones.relativeFlux(phiv);
phi = phiv*rhof;
No problems with that during test, so far.
Niklas
Multiple reference frame Lim FLUENT 1 April 19, 2008 10:46
Multiple reference frame in centrifugal fan Peter Main CFD Forum 0 April 8, 2008 05:37
Multiple reference frame H.A.S FLUENT 0 April 18, 2007 11:13
Multiple reference frame Boundaries H.A.S FLUENT 0 April 3, 2007 12:45
Multiple reference frame H.A.S FLUENT 2 April 3, 2007 04:32
