Home > Forums > OpenFOAM Running, Solving & CFD
Making Diracbs delta function
Old   November 30, 2008, 07:52
Default createMpSource.H:17: error: no
Henrik Rusche
henrik is on a distinguished road
createMpSource.H:17: error: no matching function for call to 'Foam::fvMesh::findCell(Foam::dimensionedVector&)'
/home/sea/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/primitiveMesh.H:662: note: candidates are: Foam::label Foam::primitiveMesh::findCell(const Foam::point&) const
The compiler trys to tell you that your variable sp of type dimensionedVector cannot automatically converted into a point. Try sp.value(). (Vectors can be converted into points)
Henrik
henrik is offline   Reply With Quote
Old   December 1, 2008, 06:14
Default Dear Henrik, Thank you very
Seiji Adachi
seiji_adachi is on a distinguished road
Dear Henrik,
Thank you very much for your reply.
Now I understand the difference between point(=vector) and dimensionedVector. The latter has a name and dimensions in addition to its value. This is why value() is needed to extract the value here. I made the same mistake at line 19. The code was rewrote as follows and it worked!
// Add value of 1/v to deltaFunc at the point of sp!!!
label celli(mesh.findCell(sp.value()));
dimensionedScalar vol = mesh.V()[celli];
deltaFunc[celli] = 1.0/vol.value();
Cheers,
Seiji
seiji_adachi is offline   Reply With Quote
Thread Tools
Trackbacks are On
Scalar Dissipation - delta function assumption Tristan Collins FLUENT 0 December 13, 2007 08:15
How to calculte \Delta t from CFL? Annie Main CFD Forum 4 March 23, 2005 10:48
LES delta turb Main CFD Forum 2 March 2, 2005 15:27
Making the density a function additional variab. Sebastien Perron CFX 4 August 8, 2003 08:03
Delta wing Thomas Pettersson FLUENT 1 April 22, 2000 20:18
