Unable to run a case with OpenFOAM 1.6-ext that works with OpenFOAM 2.3.0 |
May 15, 2014, 05:17 |
Jiri
Rep Power: 13 |
I have of 2.3.0 and I installed 1.6ext version. However although I use command of16ext to switch openfoam version I cant make run cases which run under openfoam 2.3.0, such as simpleFoam.. Where is the mistake? |
May 15, 2014, 05:27 |
#2 | |
what exactly did you mean by Quote:
There can be lots of things: slightly different dictionary formats, wrong environment variables, etc. |
May 15, 2014, 05:32 |
Jiri
Rep Power: 13 |
I mean - I have a simple case I created - a box with velocity inlet and pressure outlet (k - eps model) which worked fine in of 2.3.0. And when I write command to switch from 2.3.0. to 1.6ext and write "simpleFoam" to start calculation, it writes
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext-064a6e9f332e Exec : simpleFoam Date : May 15 2014 Time : 11:33:24 Host : 96GB PID : 6070 Case : /home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p --> FOAM FATAL IO ERROR: Cannot open include file "/home/openfoam/OpenFOAM/OpenFOAM-1.6-ext/etc/caseDicts/setConstraintTypes" while reading dictionary "/home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/0/p::boundaryField" file: /home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/0/p at line 24. From function functionEntries::includeEntry::includeEntry(dictio nary& parentDict,Istream& is) in file db/dictionary/functionEntries/includeEntry/includeEntry.C at line 105. FOAM exiting .... Have got any idea, what is wrong? |
May 15, 2014, 05:44 |
Can you show your 0/p file? I guess the problem is in the line
#include "${WM_PROJECT_DIR}/etc/caseDicts/setConstraintTypes" |
May 15, 2014, 05:57 |
Jiri
Rep Power: 13 |
I uploaded the case here http://leteckaposta.cz/843824944. You can have a look at the files. I will be really glad for help.
May 15, 2014, 06:22 |
Well, you need to remove (or comment out) line:
May 15, 2014, 07:32 |
Jiri
Rep Power: 13 |
Thank you,
however I still have the message: --> FOAM FATAL IO ERROR: keyword div((nuEff*dev(grad(U).T()))) is undefined in dictionary "/home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/system/fvSchemes::divSchemes" file: /home/openfoam/JiriV-2.3.0/run/tutorials/incompressible/pokusy/schodek/Merge_schodek/schodek_good_mesh_k-eps/system/fvSchemes::divSchemes From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 396. FOAM exiting Although I commented out the div((nuEff*dev(grad(U).T()))) in /fvSchemes (I also tried to comment out other lines in fvSchemes) it still writes the message above (I tried to close and open terminal as well) |
May 15, 2014, 09:06 |
Well, you can't solve everything by just commenting it out
If you go to 1.6 tutorials, you'll find, this line Code:
div((nuEff*dev(T(grad(U))))) Gauss linear; Code:
div((nuEff*dev(grad(U).T()))) Gauss linear; Code:
tmp<fvVectorMatrix> UEqn ( fvm::div(phi, U) + turbulence->divDevReff(U) ); Code:
tmp<fvVectorMatrix> kEpsilon::divDevReff(volVectorField& U) const { return ( - fvm::laplacian(nuEff(), U) - fvc::div(nuEff()*dev(T(fvc::grad(U)))) ); } Code:
tmp<fvVectorMatrix> kEpsilon::divDevReff(volVectorField& U) const { return ( - fvm::laplacian(nuEff(), U) - fvc::div(nuEff()*dev(fvc::grad(U)().T())) ); } |
May 15, 2014, 09:52 |
#9 |
Jiri
Rep Power: 13 |
that is true, commenting out is a dull kind of solutin.
Thank you very much indeed mate, I finally used the whole files fvSchemes and controlDict from the 1.6ext tutorial, cause there were other fvSchemes errors. Anyway, I would like to ask crucial question that I yearn to sort out, that is how could I run MRFSimpleFoam tutorial? There is folder "Make" and files createFields.H and MRFSimpleFoam.C, I do not know how to make it run. Could you give me a clue ? |
May 15, 2014, 10:07 |
#10 |
If you're talking about tutorials/incompressible/MRFSimpleFoam/mixerVessel2D from 1.6 then there is Allrun script. In the folder tutorials/incompressible/MRFSimpleFoam/MRFSimpleFoam solver itself is located, it's not a case folder.
May 15, 2014, 10:30 |
#11 |
Jiri
Rep Power: 13 |
Yes, I thought it is two separate folders ( mixerVessel2D and MRFSimpleFoam) I am just working with it (due to Allrun in mixerVessel2D).
Thanks a lot |
May 16, 2014, 03:56 |
#12 |
Jiri
Rep Power: 13 |
I am just going through the mixeVessel2D files. I obviously do not understand, what is actually the logic of MRFSimpleFoam - in this case I cannot see any mixing plane and there is no segment rotating, it is full circle.
I assumed in polymesh/boundary there will be a definition of cyclicGGI or GGI.. but there are just walls for rotor and stator. Where can I find a case with rotating segmend connected via mixing plane to another segment or to a draft tube? |
May 16, 2014, 08:52 |
#13 |
Jiri
Rep Power: 13 |
I uploaded my rotor stator case I wish to simulate by using 1.6ext. http://leteckaposta.cz/897752382 I d be very happy if you had little time to have a look at the case. |
May 18, 2014, 15:50 |
#14 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Jiri: Quote:
For more information, please read my revised post #7 on this thread: http://www.cfd-online.com/Forums/ope...tml#post492711 For future reference, looking for tutorials that have this mixing-plane feature, at least for now, can be done with this command: Code:
find $FOAM_TUTORIALS -iname "*mixingPlane*" Best regards, Bruno |
May 19, 2014, 08:11 |
#15 |
Jiri
Rep Power: 13 |
Thank you much for your information, I am just struggling with installation of extend -3.0. I am stuck on the step 11 which should last max 30 minutes, I waited nearly two hours and nothing.
May 21, 2014, 04:52 |
#16 |
Jiri
Rep Power: 13 |
I successfully installed extended version 3.0. I have meshes of stator.msh and rotor.msh which were created in commercial software. In OF 2.3.0 I used fluent3DMeshToFoam to convert meshes .msh to OF format. Then I used mergeMeshes and meshes were merged together. However, I want to use mixing plane between rotor and stator, using OF3.0. I cant find where to set revolution of the rotor as I cant find it neither in tutorial mixingPlaneAxial nor in mixingPlaneDomADomB. Moreover when typing simpleFoam a receive the error message: Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Initializing the mixingPlane interpolator between master/shadow patches: outflow/wall-4 --> FOAM FATAL ERROR: Face zone name outflowZone for mixingPlane patch outflow not found. Please check mixingPlane interface definition. From function label mixingPlanePolyPatch::zoneIndex() const in file meshes/polyMesh/polyPatches/constraint/mixingPlane/mixingPlanePolyPatch.C at line 724. Cause in polymesh/sets I have only folders: highAspectRatioCells nonOrthoFaces region0 region1 wrongOrientedFaces How shall I get there files with zones, as in tutorial mixingPlaneAxial |
Display Modes | |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Test directory missing in OpenFOAM 1.6 ext | andrewryan | OpenFOAM | 2 | March 20, 2011 16:41 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 16:45 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
Help I canbt run FoamX report Unable to contact name server error | cornerstone | OpenFOAM Installation | 0 | May 3, 2006 02:14 |
