Hi everybody,
I try to run
Hi everybody,
I try to run an OpenFOAM 1.3 icoFOAM case under 1.5 and got the following error: Exec : icoFoam Date : Nov 26 2008 Time : 16:01:04 Host : foam4 PID : 1180 Case : /home/foam15/OpenFOAM/foam15-1.5/run/tutorials/icoFoam/E345-51 nProcs : 1 // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading transportProperties Reading field p #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7fe3420] #3 Foam::tmp<foam::field<double> > Foam::fvPatch::patchInternalField<double>(Foam::UL ist<double> const&) const in "/home/foam15/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam" #4 Foam::zeroGradientFvPatchField<double>::zeroGradie ntFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so" #5 Foam::fvPatchField<double>::adddictionaryConstruct orToTable<foam::zerogradientfv patchfield<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so" #6 Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam" #7 Foam::GeometricField<double,>::GeometricBoundaryFi eld::GeometricBoundaryField(Fo am::fvBoundaryMesh const&, Foam::DimensionedField<double,> const&, Foam::dictionary const&) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam" #8 Foam::GeometricField<double,>::readField(Foam::Ist ream&) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam" #9 Foam::GeometricField<double,>::GeometricField(Foam ::IOobject const&, Foam::fvMesh const&) in "/home/foam15/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam" #10 main in "/home/foam15/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam" #11 __libc_start_main in "/lib/tls/i686/icoFOAM cmov/libc.so.6" #12 Foam::regIOobject::readIfModified() in "/home/foam15/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam" Segmentation fault Any suggestions? |
