Hi
I am adding turbulence
Hi
I am adding turbulence models similar to what is done in sonicTurbFoam I have an error in compilation on the line turbulence->correct; with the rather strange error "statement cannot resolve address of overloaded function." I would appreciate any advice on the above issue Thanks Srinath |
Sorry for the silly post.
It
It was a typo. Should have read turbulence->correct(); |
try with parentheses:
turbule
turbulence->correct(); ;-) |
Oliver did you manage to add turbulence to rhoCentralFoam? If you did, would you be kind enough to share you successes ... |-P
The layout of rhoCentralFoam is quite a bit different than the other turbulent compressible solvers. Thanks |
Oops, I propositioned the wrong person. I meant to to ask 'srinath' if he managed to add turbulence to rhoCentralFoam and if you so, would you he be kind enough to share his successes.
Upon finding a paper published by the creators of rhoCentralFoam, I managed to understand how it was working and have added turbulence to it.
I am in the midst of testing it on some canonical problems and when I'm confident it works as expected I will post the source for it. I've called it rhoCentralTurbFoam. |
Bit of an update ... I managed to get rhoCentralTurbFoam to work. However, the Co stability requirements force the timestep to be so small that it takes a long simulation and wall time to converge. That last thing I was trying to do was to get local (spatially-varying) timestepping working but haven't had the time lately to dig into it further.
I will pass on what I have to anyone if they want it. |
Are there any updates on this? I am very interested in this solver.
OpenFOAM 2.0.x has a version of rhoCentralFoam with turbulence enabled (RANS / LES).
Thanks, I will try that!
rhocentralfoam and turbulence model
Could anyone send me a file of fvsolution and fvshemes of a sample test with rhocentralFoam and turbulence model? I mean which solvers should be used for K and epsilon? I try some ones but it diverges.
Thanks |
Does someone have an example fvSolutions file with turbulence? I am also curious with how you would need to change or add any new variables in the initial conditions folder.
