-   -   Parallel run with engineFoam (http://www.cfd-online.com/Forums/openfoam-solving/58300-parallel-run-enginefoam.html)
francesco November 21, 2008 12:01
Dear all, I've recently mov
Dear all,
I've recently moved to OpenFoam and tried to run the basic tutorials on our local cluster. It appears that everything was ok for the cavity case but when I tried the engineFoam case the following error appear:
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
Exec : engineFoam -case /home/term/contino/OpenFOAM/contino-1.5/run/tutorials/engineFoam/kivaTest -parallel
Date : Nov 21 2008
Time : 14:25:30
Host : lmexec-50
PID : 24319
Case : /home/term/contino/OpenFOAM/contino-1.5/run/tutorials/engineFoam/kivaTest
nProcs : 4
Slaves :
3
lmexec-50.24320
lmexec-137.7168
lmexec-137.7169
Pstream initialized with:
floatTransfer : 1
nProcsSimpleSum : 0
commsType : nonBlocking
Create engine time
Create mesh for time = -180
Selecting engineMesh layered
deckHeight: 0.085639
piston position: 0
Reading combustion properties
Ignition switched off
Reading thermophysical properties
Selecting thermodynamics package hhuMixtureThermo<inhomogeneousmixture<sutherlandtr ansport<speciethermo<janafther mo<perfectgas>>>>>
2 additional processes aborted (not shown)
[lmexec-137:07168] *** An error occurred in MPI_Recv
[lmexec-137:07168] *** on communicator MPI_COMM_WORLD
[lmexec-137:07168] *** MPI_ERR_TRUNCATE: message truncated
[lmexec-137:07168] *** MPI_ERRORS_ARE_FATAL (goodbye)
mpirun noticed that job rank 0 with PID 24319 on node lmexec-50 exited on signal 15 (Terminated).
I've decomposed my computing domain with decomposePar as I did for the cavity case. And engineFoam works fine on a node of the same cluster without parallelizing it. I've also tried the same procedure on my own bi-proc computer resulting in the same error.
Please feel free to ask any questions requested to clarify the problem.
Hope somebody will be able to help me.
Francesco.
francesco November 24, 2008 04:07
I've tried the same process wi
I've tried the same process with dieselEngineFoam and it crashed again with the same errors.
Perhaps this will help.
Francesco.
francesco November 24, 2008 06:37
It appears that the error with
It appears that the error with dieselFoam was not exactly the same but was in the definition of fu and ft in the initialization directory.
But the problem remains for engineFoam.
mattijs November 24, 2008 16:17
Sounds like you've found a bug
Sounds like you've found a bug. Can you please report it in OpenFOAM-bugs with your exact set-up?
