Single Droplet deformation
Old   November 17, 2008, 10:37
Default Hello, I am new to openFoam
sesha
hamsadhwani8 is on a distinguished road
I am new to openFoam and want to set up a case to study the deformation of a single droplet. Can someone help with this?
Thanks,
ss
hamsadhwani8 is offline   Reply With Quote
Old   November 17, 2008, 13:40
Default Start by learning how to use t
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Start by learning how to use the interFoam solver. Refer to the "Dam break" tutorial for a quick start guide on this.
msrinath80 is offline   Reply With Quote
Old   November 20, 2008, 13:10
Default Hi Srinath, THanks for your
sesha
Hi Srinath,
THanks for your message. I have been able to run the tutorials on damBreak. Now, I am trying to set up the fluid as a droplet in the same domain. someone in one of these threads has suggested using the following piece of code. However, I am not sure where exactly they want me to put this code! Any suggestions?
scalar xC(0.0), yC(0.0); // Center values of for the cross section.
forAll(gamma,gI)
if (sqr(mesh.C()[gI].component(0) - xC) + sqr(mesh.C()[gI].component(1) - yC) <= sqr(radius))
gamma[gI] = 1;
Old   November 20, 2008, 13:22
Default Also, just so you know, I use
sesha
Also, just so you know, I use openfoam version 1.5 so I think funkySetFields need not be installed?
Thanks,
ss
Old   November 20, 2008, 15:16
Default Everything you need to know is
Everything you need to know is here[1]. Please search the forum carefully before posting. Thank Bernhard for both the utility and providing a simple expression for creating a fluid sphere.
PS: I doubt that funkySetfields is available with the stock OF 1.5 (from OpenCFD). That post has instructions on how to pull it out from OF 1.5.x (dev).
Good Luck!
References:
[1] http://www.cfd-online.com/OpenFOAM_D...ges/1/368.html
Old   November 20, 2008, 17:06
Default Hi s s With the release of
jaswi is on a distinguished road
Hi s s
With the release of 1.5 version a new topoSetSource is available. What you want to do requires no coding. please use sphereToCell for your purpose. FSF is a tool which allows the complete freedom to go for general shapes, offcourse if you know the mathematical expression
Look into tutorials/lesCompressibleInterFoam/
and there is a test case which initialzes a bubble using this topoSetSource.
Also I request you to please use your real name and activate your email otherwise posting on the forum gives a feeling of yahoo chat rooms :-)
Kind Regards
Jaswi
jaswi is offline   Reply With Quote
Old   November 20, 2008, 17:23
Default Hello Jaswinder, Thanks for th
Hello Jaswinder, Thanks for that pointer.
Old   November 22, 2008, 11:12
Default Srinath and Jaswinder, Than
sesha
Thanks for your comments.
ss
MULTIPHASE - SINGLE DROPLET ozgur FLUENT 3 June 12, 2018 13:22
Boundary Condition for single droplet evaporation Deepak Kumar Mandal Siemens 0 January 30, 2007 09:25
deformation Dominik Main CFD Forum 1 July 20, 2005 19:14
benchmark of droplet deformation ptyue Main CFD Forum 0 March 26, 2003 10:39
single liquid fuel droplet combustion(unbounded) Dipankar Chatterjee FLUENT 0 March 18, 2002 06:35
