just a quick one about
just a quick one about the turbulenceProperties Whats the different between a turbulence model (e.g. k-epsilon) with settings the "turbulence" keyword set to "off" or "on" ? set to "on", results with k and epsilon and all is fine! set to "off", the result are without k epsilon components, but a k-epsilon Model without k epsilon ???? How work this ? thanks and best regards , Sven |
I think "off" removes the turb
I think "off" removes the turbulence model altogether; so it will simulate a laminar flow. I'm not quite sure what the difference is between this and using the "laminar" turbulence model, which I think has the same effect. Seems like a redundancy.
Gavin |
thanks Gavin,
i compare two
thanks Gavin,
i compare two cases, first the Modell laminar and second the K-eps with turbulence"off". all dict the same! but the solution is not the same, the residual curves are also different K-eps with turbulence"off" (conclusion without k and epsilon components) convergent quick and clean (maybe too clean) but the laminar model convergent rougher than the keps ! ? usually laminar convergent quicker than keps! http://www.cfd-online.com/OpenFOAM_D...es/1/10007.jpg best regards , Sven |
laminar off = laminar solution
laminar off = laminar solution with turbulence off
laminar on = laminar solution with turbulence on kepsilon_off = k-epsilon solution with turbulence off kepsilon_on = k-epsilon solution with turbulence on |
