IcoDyMFoam how to define more than one rotating regions
Old   November 14, 2008, 08:25
Default Hello everyone, I'm using
Naoko Oyama
naoko_oyama is on a distinguished road
Hello everyone,
I'm using 1.4.1-dev and trying to set up a rotating geometry case with GGI between the rotating part and the static part.
It works pretty fine when I want to rotate a single region, but I cannot manage to make two rotating regions (with different axes).
My question is; Has anyone worked with multiple rotating regions?
I learned that the code (mixerGgiFvMesh.H/ mixerGgiFvMesh.C) defines the rotating region according to the origin of the rotating axis. So I suppose I need to make a change in the code in order to make two regions rotate, but I don't have much experience in C++ and am still struggling with the code.. I'm trying to simply double the definition in order to make two rotating parts, but is this the right strategy?
If anyone had experienced this or has any ideas or advices how to do this, I would love to know...
Thank you in advance
Naoko
naoko_oyama is offline   Reply With Quote
how to define rotating scheme Amir FLUENT 5 December 22, 2008 16:32
how to define different regions in icem ? Hammam CFX 3 July 9, 2007 12:56
Problem with icoDyMFoam philippose OpenFOAM Running, Solving & CFD 19 March 7, 2007 12:06
How to use icoDyMFOAM soup OpenFOAM Running, Solving & CFD 7 November 24, 2006 03:25
How to use UDF to define a rotating wing lyf FLUENT 3 April 7, 2004 04:31
