RhoPorousSimpleFoam RhoSimpleFoam
Old   July 22, 2008, 09:36
Default Hello again, Now I upgraded
Samuel Vogel
spv24 is on a distinguished road
Hello again,
Now I upgraded to OpenFOAM 1.5. And I still would like to have an turbulent, compressible Solver. I took the RhoPourousSimpleFoam case in the tutorials and edited the pourousZones.c File. I deleted the entries below porosity and porosity itself. And put a 0 above the brackets. Is tihs the correct way to get rid of the porosity calculation for having only the RhoSimpleFoam solver left?
Thanks
Sammy
spv24 is offline   Reply With Quote
Old   July 23, 2008, 00:53
Default you are right ..this will solv
Pawan
pawan is on a distinguished road
you are right ..this will solver compressible turbulent fluid flow. i have also done it in similar fashion and has already validated it against fluent. cheers
pawan is offline   Reply With Quote
Old   October 8, 2008, 01:21
Default Hello Pawan, We are also tryi
santhosh
santoo is on a distinguished road
Hello Pawan,
We are also trying to set a case for compressible turbulent flow, we are trying to set a case for rhoSimpleFoam but cound not succeed. It would be great help for us if you can share your case with us. My mail id is abhishekhare@gmail.com
santoo is offline   Reply With Quote
Old   November 12, 2008, 09:17
Default Hello all, Maybe my questio
paul_mathis
Hello all,
Maybe my question fits not very well in here, but I chose this thread as there seems not to be much discussion on rhoSimpleFoam topics in the last few months...
We are computing compressible turbulent flow in centrfugal impellers, that means in single rotation frame, and comparing OF results to those from a commercial code. The flow pattern of the fluid (air) looks reasonable, so does the static pressure rise. However, the mass flow is computed 4 % smaller and the rise in temperature is significantly smaller (10 %).
We modified the rhoSimpleFoam so that the momentum equations are solved in single roating frame (including SRFModel, see attached files). At the inlet, a rotatingTotalPressure BC for p and a rotatingPressurerInletOutletVelocity for U is specified.
I notice, some users do have much experience with rhoSimpleFoam. Does any of you have experience with too small temperature rise? Or maybe there is a mistake in my solver?
Cheers, Paul
\Client\C$\Documents and Settings\c563640\Desktop\rhoSimpleFoamRel.C
Old   November 12, 2008, 09:19
Default http://www.cfd-online.com/Ope
paul_mathis
\Client\C$\Documents and Settings\c563640\Desktop\createFields.H
BC for rhoSimpleFoam uli_u OpenFOAM Running, Solving & CFD 77 April 4, 2013 11:28
RhoSimpleFoam maritozzo OpenFOAM Running, Solving & CFD 1 April 30, 2010 18:18
RhoSimpleFoam jphandrigan OpenFOAM Running, Solving & CFD 18 March 29, 2009 11:05
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
RhoSimpleFoam luca OpenFOAM Running, Solving & CFD 0 August 22, 2005 12:26
