Hi everyone
I'm just starting
Hi everyone
I'm just starting with OpenFOAM. I want to simulate oil mist filtration and I chose the solver twoPhaseEulerFoam. After changing some of the files and filling in my parameters I run the calculation. Then I get this error message: DILUPBiCG: Solving for alpha, Initial residual = 1, Final residual = 7.5185e-14, No Iterations 3 Dispersed phase volume fraction = 5.09482e-08 Min(alpha) = 0 Max(alpha) = 0.0005236 DILUPBiCG: Solving for alpha, Initial residual = 0.00235546, Final residual = 1.54916e-13, No Iterations 2 Dispersed phase volume fraction = 5.09482e-08 Min(alpha) = -3.26858e-18 Max(alpha) = 0.0005236 #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7f9d420] #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::DICSmoother::DICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<foam::field,> const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&) in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::lduMatrix::smoother::addsymMatrixConstructor ToTable<foam::dicsmoother>::Ne w(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<foam::field,> const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&) in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<foam::field,> const&, Foam::FieldField<foam::field,> const&, Foam::UPtrList<foam::lduinterfacefield> const&, Foam::Istream&) in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::GAMGSolver::initVcycle(Foam::PtrList<foam::f ield<double> >&, Foam::PtrList<foam::field<double> >&, Foam::PtrList<foam::ldumatrix::smoother>&) const in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #8 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so" #9 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/schairer/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so" #10 main in "/home/schairer/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/twoPhaseEul erFoam" #11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #12 Foam::regIOobject::readIfModified() in "/home/schairer/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/twoPhaseEul erFoam" Floating point exception Does anybody know what this is about? I didn't change anything in the directories mentioned in there. I'd be grateful for some help. Cheers, Sara |
Hi Sara,
The listing says:
Hi Sara,
The listing says: Quote:
So it seems there is something wrong with your pressure settings (boundary conditions, initial conditions). I hope this is helpful, Dragos |
Hi Drago
Maybe it was. I chan
Hi Drago
Maybe it was. I changed alpha, too. Because it was set to 0 in the internal field and I thought that maybe somewhere during the calculation it tried to divide by zero. In the p file I only changed the expression of the value from 1e+05 to 100000. And I changed zeroGradient for the boundaries to fixedValue... At least it works now, though I'm not sure if it's doing what I want it to do ;) Anyway, thanks a lot for the quick answer. Cheers, Sara |
