Bubble in zero gravity conditions
Old   April 28, 2008, 12:34
Default Hello World. I'm working to
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I'm working to compute the following problem:
Concidering a liquid in the form of a SQUARE block in air with zero gravity.
Due to surface tension the liquid must obtain the contour of a sphere.
After meshing and setting the appropriate fields (gamma,U) I have a smooth silmulation of the deforming bubble.
It looks pretty well, but I doesn't come to rest.
Due to friction the liquid has to reach a state of rest. But it doesn't even after a endTime of 50.
How Do I implement friction?
Or Do I have even have to increase the running time ...
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   April 28, 2008, 15:24
Default Hi Sebastian It sound like
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Sebastian
It sound like a very interesting experiment Friction should be included in terms of the diffusion term laplacian(mu,U) in the UEqn, thus if you increase mu in your transportProperties dict in case/constant/, then the dissipation of energy will increase.
Hope it helps.
- Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   April 29, 2008, 14:20
Default I think I will have to take a
sega's Avatar
Sebastian Gatzka
I think I will have to take a look at the corrosponding dimensionless description on this case.
I presume it's Re^2/We ...
I will write next time I get some results.
Old   April 29, 2008, 14:55
Default Hi Sebastian You inspired
ngj
Hi Sebastian
You inspired me to make some more visually pleasing bubbles, even though the simple cube in itself is very interesting, so please enjoy this small movie:
http://www.student.dtu.dk/~s001581/O.../cubeStick.mpg
In this I got the same problem as you, namely that the kinetic energy is very slow dissipating, the movie is 100s. Note that the smaller sphere is completely steady but the larger once are vibrating.
Best regards,
Niels
Old   April 29, 2008, 15:50
Default Well, that looks awesome... E
sega's Avatar
Sebastian Gatzka
Especially for a beginner, like me ...
Old   April 30, 2008, 04:03
Default Thankshttp://www.cfd-online.co
ngj
Thanks
Old   April 30, 2008, 04:37
Default Obviously you are "very into i
sega's Avatar
Sebastian Gatzka
Obviously you are "very into it".
Would you mind having a look at my post about seeting non-uniform fields?
http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/7461
I'm really messed up with this problem.
Old   April 30, 2008, 04:48
Default Thanks, though I think you are
ngj
Thanks, though I think you are exaggerating a bit I have been reading that post as well, and unfortunately I cannot help you, because I have not tried to initialize fields with anything but setFields.
Though I like the way you tried to overcome the problem in creating a sphere Very creative.
- Niels
Old   April 30, 2008, 05:46
Default Actually the two problems are
sega's Avatar
Sebastian Gatzka
Actually the two problems are not linked at all.
I have two different problems to perform:
1. This one: Deformation of a square under zero gravity.
2. Rise of a bubble to it's terminal velocity
For the second one I need the bubble...
Get it?
Old   April 30, 2008, 06:03
Default Ah, yes. But now that you know
ngj
Ah, yes. But now that you know how to create a bubble in zero gravity, then after doing that, add gravity to the system and it will rise. I know that it is computationally heavy, but it is a way out of the problem about generating the bubble.
- Niels
Old   May 4, 2008, 08:54
Default Now that it looks finaly that
  #11
sega's Avatar
Sebastian Gatzka
Now that it looks finaly that I did the calculation right.
How can I compare the final shape of the fluid area with a circle?
I thought about creating the contour-plot for gamma=0.5, which does look really good like a cicle.
But how am I going to get addition data corrosponding to a circle inside this plot?
Or do I have to export the contour plot so I can handle the comparison in an other software - like MATLAB, or something similar?
Greetings.
Old   May 9, 2008, 03:36
Default Hello, Me again. I checked
  #12
sega's Avatar
Sebastian Gatzka
Hello, Me again.
I checked some literature about how to set up this problem right:
Validation of Advanced Computational Methods for Multiphase Flow (ed. Lemonnier, Jamet, Lebaigue, 2005)
The simulation is running smoothly.
But I have some problem with the pressure inside the liquid.
Pressure-Difference should be delta_p = sigma / Radius for my 2D-case.
Unfortunately the simulation does not reach this state. The pressure inside the liquid is a little bit smaller - well, almost 6%.
The Radius of the liquid-circle is caluclated right.
Any ideas what went wrong?
Old   May 9, 2008, 04:15
Default Hi Sebastian I can come up
  #13
ngj
Hi Sebastian
I can come up with a couple of possibilities, which might explain what you see. I have put them in order, so the first is the one I think might have the largest impact:
1. I have experienced that you have to be careful when initializing the gamma-field. If the edges of your initial cube of water is not perfectly aligned with the faces in the grid you will get a larger or smaller amount water (gamma = 1) in your domain. As p < 1 suggest that you have to much water in your calculation. You could test it with a small command such as:
sum(mesh.V() * gamma) / sum(mesh.V())
and if this is not identical to "pi * thickness in z-direction" in your case, your radius cannot be 1, assumed sigma = 1.
2. Your circle is not perfectly circular, even though close, so in these flatter parts the curvature is smaller and thus the contribution to the internal pressure is smaller.
3. The surface tension is based on snGrad(), thus there is a numerical error and if your mesh does not represent the interface perfectly these would affect the surface tension and therefor the inner pressure.
Thanks for sharing the reference on the book, I will look into that.
Have a nice weekend,
Niels
Old   May 9, 2008, 04:25
Default Ooops, you should not divide b
  #14
ngj
Ooops, you should not divide by sum(mesh.V()).
- Niels
Old   May 9, 2008, 07:51
Default Thanks so far. But can you te
  #15
sega's Avatar
Sebastian Gatzka
Thanks so far.
But can you tell me where I have to enter the calculation commands?
In a terminal windows?
Or in some kind of file?
I have some problems getting into the whole programming of OpenFOAM. I think I have to take a really close look into the programmers guide ...
BTW: I have come upon a web-site which contains most of the numerical test cases from the book mentioned above. Have a look at:
http://test.interface.free.fr/
Old   May 9, 2008, 08:55
Default Hi Sebastian After a second
  #16
ngj
Hi Sebastian
After a second thought, the information you are after is actually given to you directly in the log-file. Because the "Liquid phase volume fraction" is written each and every time step. Thus multiply that number with the total volume, and you will have the water volume.
Thanks for the link, it looks really good
- Niels
Old   May 9, 2008, 13:53
Default Hi Niels. Ok, there is too
  #17
sega's Avatar
Sebastian Gatzka
Hi Niels.
Ok, there is too much liquid. Exactly 2.5 % plus.
The liquid phase volume fraction does work-
So, Do you have any ideas about how I can change this?
I'm using a 100x100 discretization.
Do you think it's necessary to increase this number to get a sharper interface?
Or can you think of an alternative way to make sure the gamma-field is set up to a face on the grid?
Old   May 9, 2008, 16:46
Default Well that is good, because tha
  #18
ngj
Well that is good, because that explains partly you underprediction of your pressure.
I have myself had problems with setting the gamma-field as no tool to set a fraction if the criterion is only partly fullfilled in a cell exists. I have considered making such a tool but it is far into the future.
My advise would be to go back to the cube initial field and then make you mesh out of 9 blocks, where the center block is [-sqrt(pi) / 2; sqrt(pi) / 2] x [-sqrt(pi) / 2; sqrt(pi) / 2]. This should give you a perfectly sharp interface, even though it is quite cumbersome.
- Niels
P.S. The book you mentioned is not available though my university library, so could you give a short description. I might consider buying it. Is it heavy on the mathematical treatment or is it more like a handbook with guidelines and test cases, i.e. with a more engineering kind of approach?
Old   May 10, 2008, 08:03
Default Well, that sounds like a good
  #19
sega's Avatar
Sebastian Gatzka
Well, that sounds like a good solution.
I will try this one now.
About the book. The PDF-Files online are exactly the same as the cases in the book.
As the book is stuffed with about 30 problem problem setups there is not so much space for mathematics. Its more or less a handbook how to set up these problems right and which sections of the problem need higher attention.
Old   May 10, 2008, 09:08
Default Ok, the problems with the new
  #20
sega's Avatar
Sebastian Gatzka
Ok, the problems with the new mesh are subject to this threat:
http://www.cfd-online.com/OpenFOAM_D...tml?1210424711
GRAVITY Lorenzo FLUENT 0 September 19, 2007 10:10
gravity-table.scm scheme file for trans gravity Shankar FLUENT 0 May 31, 2006 04:30
Turbulent boundary conditions for bubble column anjai FLUENT 12 October 17, 2005 06:34
gravity driven flow- boundary conditions? Shankar FLUENT 4 November 26, 2003 15:45
Boundary Conditions for Bubble Column cfd-novice FLUENT 0 April 14, 2003 01:50
