Flow around a cylinder Vortex Shedding ForceCoeffs
Old   November 2, 2008, 21:11
Default Hi, I am currently getting
Daniel Harlacher
harly is on a distinguished road
I am currently getting familiar with OpenFOAM-1.5 and I am trying to create a Cl/Cd plot for a cylinder. I have got a paper to compare my results to and I am having a hard time getting to a proper Result.
I am using Icofoam for a round cylinder and Re=105. There is vortex shedding but the coefficients don't match - they are to high almost twice the Cd.
I played around a lot and the fact, that the same Case with the same Re - number can produce different results on how I choose U and nu was very confusing.
I will upload my files this night and post the links.
Until then I really would like to know if some of you have successfully compared OpenFOAM Coefficients with a paper or an other solver like fluent/cfx using air and what your configuration were for nu.
I would love to summarize every input after we solved this Problem so everyone can profit from it.
yours
harly
harly is offline   Reply With Quote
Old   November 3, 2008, 01:50
Default Here are the links to my files
Daniel Harlacher
Here are the links to my files. In this case I used U = 1 and defined nu to fit the Re = 105.
It works pretty well except I cannot evaluate the results - so I want to run the same case with air but when I change the velocity and nu to air I am not getting a proper vortex shedding.
My files:
http://home.arcor.de/daniel.harlacher/www/U
http://home.arcor.de/daniel.harlacher/www/p
http://home.arcor.de/daniel.harlacher/www/controlDict_1
http://home.arcor.de/daniel.harlacher/www/fvSolution
http://home.arcor.de/daniel.harlacher/www/fvSchemes
http://home.arcor.de/daniel.harlache...rtProperties_1
what do I have to change if I want to use air ? (I thought only U and nu, but that didn't work that well...)
Thanks for every suggestion
Motion of cylinder due to vortex shedding ACHILLEAS TSOMPANOS FLUENT 3 November 24, 2006 04:06
Vortex shedding for square cylinder zonexo Main CFD Forum 8 March 30, 2006 16:11
Vortex shedding from a cylinder Cylinder Case Phoenics 4 February 21, 2006 09:18
Vortex shedding from a cylinder Mark Phoenics 1 May 8, 2003 13:00
Vortex Shedding Circular Cylinder Ray Mahon Main CFD Forum 1 March 15, 2002 00:38
