Dear users,
I am trying to
Dear users,
I am trying to run a case with the rasInterFoam solver. A- When I run it in serial it works. B- When I run it in parallel (the 2 processors of my computer) it works. C- When I run it in parallel (the 10 processors of our 5 computer) it crashes after 3-4 iterations. For C, I noticed that Courant number mean and Courant number max are different after the 3rd iteration. Has somebody already experienced it ? Regards, Stephane. |
Hi Stephane,
just as a first
Hi Stephane,
just as a first attempt, try to run double precision and switching floatTransfer to 0 in etc/controlDict file in the OpenFOAM installation. Have a look to this thread for a similar problem: http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/9732 Hope this helps, Francesco |
Hi Francesco,
I have switch
Hi Francesco,
I have switched float Transfert to 0 in etc/controlDict file in the OpenFOAM installation. And now it works ! It is strange that it is a default setting. At the beginning I thought that it was a mesh problem (bad quality) and then a problem with the set-up of the case. Thanks a lot Francesco. Stephane. |
Hi Francesco,
As told into
Hi Francesco,
As told into my previous message 1 case, now, is running. But I have still problems with a second one (rasInterFoam solver). It crashes after 2 iterations. Following is the message error. I hope it will help you to give me some advice. Create time Create mesh for time = 0 Reading environmentalProperties Reading field pd Reading field gamma Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Calculating field g.h Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; alphaEps 0.76923; } time step continuity errors : sum local = 6.40427e-09, global = -9.71065e-15, cumulative = -9.71065e-15 DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.8909e-11, No Iterations 613 DICPCG: Solving for pcorr, Initial residual = 0.320316, Final residual = 9.67054e-11, No Iterations 549 DICPCG: Solving for pcorr, Initial residual = 0.0921141, Final residual = 9.80646e-11, No Iterations 536 time step continuity errors : sum local = 7.15513e-18, global = 1.31447e-19, cumulative = -9.71052e-15 Courant Number mean: 3.07564e-05 max: 0.0460139 Starting time loop Courant Number mean: 0.000133683 max: 0.2 deltaT = 0.000434651 Time = 0.000434651 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = 0 Max(gamma) = 1 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -3.18278e-22 Max(gamma) = 1 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -1.22552e-23 Max(gamma) = 1 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -8.09169e-24 Max(gamma) = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.42631e-07, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 1.02311e-07, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.83972e-08, No Iterations 2 DICPCG: Solving for pd, Initial residual = 1, Final residual = 0.0342529, No Iterations 1 DICPCG: Solving for pd, Initial residual = 0.0181907, Final residual = 0.000895349, No Iterations 9 DICPCG: Solving for pd, Initial residual = 0.00189246, Final residual = 9.43079e-05, No Iterations 48 DICPCG: Solving for pd, Initial residual = 0.000543004, Final residual = 2.58335e-05, No Iterations 35 DICPCG: Solving for pd, Initial residual = 0.000215671, Final residual = 1.04855e-05, No Iterations 54 DICPCG: Solving for pd, Initial residual = 0.000105296, Final residual = 5.24317e-06, No Iterations 26 DICPCG: Solving for pd, Initial residual = 6.7759e-05, Final residual = 3.24401e-06, No Iterations 28 DICPCG: Solving for pd, Initial residual = 4.86539e-05, Final residual = 2.32617e-06, No Iterations 32 DICPCG: Solving for pd, Initial residual = 4.37942e-05, Final residual = 9.64813e-08, No Iterations 104 time step continuity errors : sum local = 1.36281e-10, global = 3.36473e-11, cumulative = 3.36376e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.0205726, Final residual = 4.41084e-11, No Iterations 4 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 2.71515e-11, No Iterations 4 ExecutionTime = 40.52 s ClockTime = 50 s Courant Number mean: 0.00013599 max: 0.901774 deltaT = 9.63991e-05 Time = 0.00053105 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -6.37168e-22 Max(gamma) = 1 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -4.39269e-23 Max(gamma) = 1.00001 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -2.32369e-23 Max(gamma) = 1.00001 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -3.39485e-23 Max(gamma) = 1.00001 DILUPBiCG: Solving for Ux, Initial residual = 0.00197648, Final residual = 1.50039e-07, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 0.0159727, Final residual = 1.1123e-07, No Iterations 3 DILUPBiCG: Solving for Uz, Initial residual = 0.00270569, Final residual = 2.41027e-08, No Iterations 4 DICPCG: Solving for pd, Initial residual = 0.000493505, Final residual = 2.40357e-05, No Iterations 67 DICPCG: Solving for pd, Initial residual = 0.000299434, Final residual = 1.41585e-05, No Iterations 38 DICPCG: Solving for pd, Initial residual = 0.000185027, Final residual = 9.08419e-06, No Iterations 29 DICPCG: Solving for pd, Initial residual = 0.000140907, Final residual = 6.72783e-06, No Iterations 32 DICPCG: Solving for pd, Initial residual = 0.000124686, Final residual = 5.81343e-06, No Iterations 34 DICPCG: Solving for pd, Initial residual = 0.000121187, Final residual = 5.70692e-06, No Iterations 37 DICPCG: Solving for pd, Initial residual = 0.000138079, Final residual = 6.27804e-06, No Iterations 37 DICPCG: Solving for pd, Initial residual = 0.000148248, Final residual = 6.95128e-06, No Iterations 39 DICPCG: Solving for pd, Initial residual = 0.000171414, Final residual = 9.66108e-08, No Iterations 113 time step continuity errors : sum local = 6.91233e-12, global = -3.09376e-12, cumulative = 3.05438e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.0916063, Final residual = 4.9656e-10, No Iterations 5 DILUPBiCG: Solving for k, Initial residual = 0.0954911, Final residual = 1.94605e-09, No Iterations 6 ExecutionTime = 56 s ClockTime = 69 s Courant Number mean: 3.0478e-05 max: 1.93885 deltaT = 9.94394e-06 Time = 0.000540994 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -8.58078e-24 Max(gamma) = 1.00001 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -8.49984e-24 Max(gamma) = 1.00001 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -1.27573e-23 Max(gamma) = 1.00001 MULES: Solving for gamma Liquid phase volume fraction = 0.808191 Min(gamma) = -2.2741e-23 Max(gamma) = 1.00001 DILUPBiCG: Solving for Ux, Initial residual = 0.598091, Final residual = 2.10026e-07, No Iterations 9 DILUPBiCG: Solving for Uy, Initial residual = 0.122759, Final residual = 1.71e-07, No Iterations 6 DILUPBiCG: Solving for Uz, Initial residual = 0.0678085, Final residual = 6.71437e-07, No Iterations 8 DICPCG: Solving for pd, Initial residual = 0.0716861, Final residual = 0.00355337, No Iterations 41 DICPCG: Solving for pd, Initial residual = 0.0298115, Final residual = 0.00115368, No Iterations 7 DICPCG: Solving for pd, Initial residual = 0.0902737, Final residual = 0.00380365, No Iterations 9 DICPCG: Solving for pd, Initial residual = 0.279904, Final residual = 0.0138083, No Iterations 4 DICPCG: Solving for pd, Initial residual = 0.451369, Final residual = 0.01378, No Iterations 4 DICPCG: Solving for pd, Initial residual = 0.521629, Final residual = 0.016842, No Iterations 3 DICPCG: Solving for pd, Initial residual = 0.61108, Final residual = 0.0233927, No Iterations 3 DICPCG: Solving for pd, Initial residual = 0.680218, Final residual = 0.0339791, No Iterations 2 DICPCG: Solving for pd, Initial residual = 0.682929, Final residual = 9.60524e-08, No Iterations 218 time step continuity errors : sum local = 8.79992e-10, global = 3.75986e-11, cumulative = 6.81424e-11 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 2.42838e-09, No Iterations 24 [0] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&)[8] [5] [6] [2] [1] ####0000 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&)#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&)Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&)[4] #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/shared/OpenFOAM/OpenFOAM-1.5 in /li"b//slhianruexd6/4OGpcecnDFPOOApMt//OlpiebnOFpOeAnMF-O1A.M5./sloi"b /[6] l#i1n uFoam::sigFpe::sigFpeHandler(int)x64GccDPOpt/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64 in "/sharedG/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [4] #1 Foam::sigFpe::sigFpeHandler(int)ccDPOpt/libOpenFOAM.so" [5] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [6] #2 in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [2] #2 in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [0] #2 in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [1] #2 in "??/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [4] #2 ?? in "/shared/OpenFOAM/OpenFO in AM"/-l1i.b564//lliibb/cl.??is??nou.x66"4 G[6] c#c3D Pvoid Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int)Opt/libOpenFOAM.so" [5] #2 ?? in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [8] #1 Foam::sigFpe::sigFpeHandler(int) in "/lib64/libc.so.6" [2] #3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/lib64/libc.so.6" [0] #3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int)?? in in "/lib64/libc.so.6" [1] #"3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int)/lib64/libc.so.6" [4] #3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [6] #4 void Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [2] #4 void Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/lib64/libc.so.6" [5] #3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/shared/OpenFOAM/Ope in n"F/OsAhMa-r1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [4] e#4 d in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [0] #4 void Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double)void Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double)/ in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [1] #4 void Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double)OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [6] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfin in "/shared/OpenFOAM/OpenF in O"A/Ms-h1a.r5e/dl/iObp/elniFnOuAxM6/4OGpcecnDFPOOApMt-/1l.i5b/fliinbi/tleiVnoulx u6m4eG.cscoD"P O[5] p#t4/ lvoid Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double)ibfiniteVolume.so" [6] #6 in "/shared/OpenFOAM/OpenFOAM-1 in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [0] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double). in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [1] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double)5/lib/linux64GccDPOpt/libfiniteVolume.so" [4] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double)iteVolume.so" [2] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double)main in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [1] #6 in "/shared/OpenFO in AM"//sOhpaenrFOeAdM/-O1p.5/lib/linux64GccDPOpt/libfiniteVolume.so" e[4] #6 nFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [2] #6 in "/shared in "/shared/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/rasInterFoam" [6] #7 __libc_start_main in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [8] #2 in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [5] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double)/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [0] #6 ?? in "/lib64/libc.so.6"main main in "/sha[6] #8 red/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [5] #6 Foam::regIOobject::readIfModified()main in "/lib64/libc.so.6" [8] #3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in main in ""//sshhaarreedd//OOppeennFFOOAAMM//OOppeennFFOOAAMM--11..55 in //"aa/ppspphllaiircceaadtt/iiOpenFOAM/OpenFOAM-1.5/applooications/bin/linux64nnG ccDPOpt/rasInterFoam" ss[4] #7 //__libc_start_mainbbiinn//lliinnuuxx6644GGccccDDPPOOpptt//rraassIInntteerrFFooa amm"" [cfs9:26785] *** Process received signal *** [0] [cfs9:26785] Signal: Floating point exception (8) [cfs9:26785] Signal code: (-6) [cfs9:26785] Failing at address: 0x45f000068a1 #[cfs9:26785] [ 0] /lib64/libc.so.6 [0x7f25b58a5660] 7[cfs9:26785] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x7f25b58a55c5] [cfs9:26785] [ 2] /lib64/libc.so.6 [0x7f25b58a5660] __libc_start_main[cfs9:26785] [ 3] /shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam5MU LES7limiterINS_8oneFieldENS_9zeroFieldES3_EEvRNS_5 FieldIdEERKT_RKNS_14GeometricF ieldIdNS_12fvPatchFieldENS_7volMeshEEERKNSA_IdNS_1 3fvsPatchFieldENS_11surfaceMes hEEESK_RKT0_RKT1_ddi+0xe6a) [0x7f25b70176fa] [cfs9:26785] [ 4] /shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam5MU LES13explicitSolveINS_8oneFieldENS_9zeroFieldES3_E EvRKT_RNS_14GeometricFieldIdNS _12fvPatchFieldENS_7volMeshEEERKNS7_IdNS_13fvsPatc hFieldENS_11surfaceMeshEEERSE_ RKT0_RKT1_dd+0x274) [0x7f25b701a4e4] [cfs9:26785] [ 5] /shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam5MU LES13explicitSolveERNS_14GeometricFieldIdNS_12fvPa tchFieldENS_7volMeshEEERKNS1_I dNS_13fvsPatchFieldENS_11surfaceMeshEEERS8_dd+0x24 ) [0x7f25b7003f34] [cfs9:26785] [ 6] rasInterFoam [0x420bb6] [cfs9:26785] [ 7] /lib64/libc.so.6(__libc_start_main+0xe6) [0x7f25b5891436] [cfs9:26785] [ 8] rasInterFoam(_ZN4Foam11regIOobject14readIfModified Ev+0x1c9) [0x41d6c9] [cfs9:26785] *** End of error message *** Regards, Stephane. |
Hi Stephane,
The default valu
Hi Stephane,
The default value for floatTransfer has been changed to 0 in the 1.5.x version, as far as I know. About your running error, it looks like the solvers are suffering. Is the problem the same in serial and in parallel? How big is your mesh? You can notice that your deltaT is reduced by a factor of 10 at each iteration. In this cases I usually check: 1. boundary conditions 2. initial conditions 3. Cells where the courant number is much higher than on the rest of the domain (there should be a "Co" application, if I'm not wrong). Sometimes bad cells, especially at the boundaries, can create many stability problems. 4. Try other solvers/schemes Hope this helps, Francesco |
| All times are GMT -4. The time now is 04:37. |
