I tried to simulate a p
I tried to simulate a pipeflow with the channeloodles-solver! Everything works fine! Afterwards I tried to use foamToVTK and get the following message: ... // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // volScalarFields : pPrime2Mean p pMean volVectorFields : U U_0 UMean volSymmTensorFields : UPrime2Mean Internal : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/OwnMesh_0_99.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/inout1/inout1_99.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/inout2/inout2_99.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/inout3/inout3_99.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/walls/walls_99.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/symmetry/symmetry_99.vtk" Time 9.9 --> FOAM Serious Error : From function IOobject::readHeader(Istream&) in file db/IOobject/IOobjectReadHeader.C at line 93 Reading "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /9.9/gradP.raw" at line 1 First token could not be read or is not the keyword 'FoamFile' Check header is of the form: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class IOobject; location "9.9"; object gradP.raw; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // volScalarFields : pPrime2Mean p pMean volVectorFields : U U_0 UMean volSymmTensorFields : UPrime2Mean Internal : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/OwnMesh_0_100.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/inout1/inout1_100.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/inout2/inout2_100.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/inout3/inout3_100.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/walls/walls_100.vtk" Patch : "/home/magnum/stur_mi/OpenFOAM/Version-1.5/run/tutorials/channelOodles/OwnMesh_0 /VTK/symmetry/symmetry_100.vtk" Time 10 --> FOAM Serious Error : Too many errors#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream& Foam::operator<<>(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&, Foam::errorManip<foam::error>) in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/foamToVTK" #3 Foam::messageStream::operator Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifSstream&() in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::messageStream::operator()(char const*, char const*, int, Foam::string const&, int, int) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::messageStream::operator()(char const*, char const*, int, Foam::IOstream const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #6 Foam::IOobject::readHeader(Foam::Istream&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #7 Foam::IOobject::headerOk() in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #8 Foam::IOobjectList::IOobjectList(Foam::objectRegis try const&, Foam::fileName const&, Foam::fileName const&) in "/home/fs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #9 main in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/foamToVTK" #10 __libc_start_main in "/lib64/libc.so.6" #11 __gxx_personality_v0 in "/home/fs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/foamToVTK" From function messageStream::operator OSstream&() in file lnInclude/messageStream.C at line 203. FOAM aborting Does anybody have some hints how to solve this problem??? Thanks, Michael |
