IFStream read float point data problem
Old   October 24, 2008, 13:14
Default Hi, Just came across an probl
liu
Xiaofeng Liu
liu is on a distinguished road
Just came across an problem related to IFStream.
I have a data file: sample.xyz which has xyz data
384165.6 4762392.7 0
384204.5 4762602.3 0
Then I simply read the data and print them on the screen. They output is:
384166 4.76239e+06 0
384204 4.7626e+06 0
The float point data x becomes an integer and the y data also lost some precision.
I believe it is related to the format. Could someone give me some hint?
The test program is:
#include "fvCFD.H"
#include "OFstream.H"
#include "IFstream.H"
int main(int argc, char *argv[])
//dem data
const int nDEMPoints=2;
scalar tmp;
label tmpl;
scalar x,y,z;
//read in the dem data
fileName dxDataFile("sample.xyz");
IFstream dataIn(dxDataFile);
for (label i=0;i<nDEMPoints;i++)
dataIn >> x >> y >> z;
Info << x << " " << y << " " << z << endl;
Info << "\nEnd\n" << endl;
return 0;
IFTest.tgz
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
IFstream binary file read type conversion problem card OpenFOAM Bugs 3 October 30, 2008 15:18
How to read data into my UDF??? Harshit Gupta FLUENT 3 June 15, 2006 03:34
float point error soundar FLUENT 0 December 17, 2004 04:23
UDF to read and write data Mcgregor FLUENT 4 June 9, 2003 14:21
read in wall data Ethan Siemens 0 March 29, 2003 16:19
