October 16, 2006, 08:51 |
Hi all,
i'm working on k-epsi
Hi all,
i'm working on k-epsilon LowRe turbulence model for compressible flow. i was trying to implement the model proposed by Chien 1982, in which the damping function for mu depends on y+=y*u_tau/nu where u_tau is the friction velocity, defined at the wall. my question is: do you have any suggestion on how to get y+ away from the wall? thank you for your replies cosimo
Cosimo Bianchini Ergon Research s.r.l. Via Panciatichi, 92 50127 Florence - ITALY Tel: +39 055 0763716 Mob: +39 320 9460153 e-mail: cosimo.bianchini@ergonresearch.it URL: www.ergonresearch.it |
October 19, 2006, 14:17 |
Have a look at wallDist which
Mattijs Janssens
Rep Power: 26 |
Have a look at wallDist which is a volScalarField of the distance to the nearest wall. Additionally you could transport the flow properties at that same nearest wall (see wallDistData) and do your calculation.
October 20, 2006, 05:24 |
Thank you really much Mattijs
Thank you really much Mattijs for answering.
Your suggestion was exactly what i was looking for. I'll try to make it run for the Chien model and after that i was thinking about implementing a two layer turbulence model. Since i'm a beginner in OF i was looking for some hints, do you maybe have some experience on this subject? Thanks again for you help cosimo
October 24, 2008, 09:36 |
I am trying to do the s
Fabian Braennstroem
Rep Power: 19 |
I am trying to do the same as cosimo using: wallPointYPlus::yPlusCutOff = 500; wallDistData<wallpointyplus> y(mesh, Yplus); Info << y.data() << endl; This does unfortunately not work: #0 Foam::error::printStack(Foam:stream&) in "/home/gcae504/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/gcae504/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt in "/lib64/tls/libc.so.6" #3 Foam::FaceCellWave<foam::wallpointyplus>::faceToCe ll() in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #4 Foam::FaceCellWave<foam::wallpointyplus>::iterate( int) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #5 Foam::FaceCellWave<foam::wallpointyplus>::FaceCell Wave(Foam::polyMesh const&, Foam::List<int> const&, Foam::List<foam::wallpointyplus> const&, Foam::UList<foam::wallpointyplus>&, Foam::UList<foam::wallpointyplus>&, int) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #6 Foam::MeshWave<foam::wallpointyplus>::MeshWave(Foa m::polyMesh const&, Foam::List<int> const&, Foam::List<foam::wallpointyplus> const&, int) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #7 Foam::patchDataWave<foam::wallpointyplus>::correct () in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #8 Foam::patchDataWave<foam::wallpointyplus>::patchDa taWave(Foam::polyMesh const&, Foam::HashSet<int,> > const&, Foam::List<foam::field<double>*> const&, bool) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #9 Foam::wallDistData<foam::wallpointyplus>::correct( ) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #10 Foam::wallDistData<foam::wallpointyplus>::wallDist Data(Foam::fvMesh const&, Foam::GeometricField<double,>&, bool) in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #11 main in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" #12 __libc_start_main in "/lib64/tls/libc.so.6" #13 __gxx_personality_v0 in "/home/gcae504/OpenFOAM/gcae504-1.5/applications/bin/linux64GccDPOpt/computeYplu s" Floating exception (core dumped) Would be nice, if anyone has a suggestion!? Fabian |
Heat transfer BC at wall- why need wall thickness? | Julie | FLUENT | 7 | February 3, 2012 21:41 |
Copy UDSI from wall to its wall shodow | thiendinh | FLUENT | 0 | December 15, 2008 05:16 |
match uds boundary condition in wall & wall-shadow | pour | FLUENT | 0 | May 20, 2008 08:56 |
LES with wall functions, wall boundary, Re 10000 | subba | CFX | 4 | July 10, 2007 05:04 |
wall & wall shadow net heat flux | Barbaros | FLUENT | 1 | August 5, 2006 02:00 |
