October 22, 2008, 04:53 |
Hi there,
I want to know if
Rina Oldek
Hi there,
I want to know if there is an explicit algorithm in OpenFoam, where multiple time steps are used in the simulations depending on the parameters or space step (delta x). Thanks Rina |
October 22, 2008, 06:16 |
I'm not entirely clear what yo
Gavin Tabor
I'm not entirely clear what you mean here; but if you construct an equation object where the only fvm:: operator used is the time derivative, then you have an explicit algorithm. Eg. for the heat equation;
solve(fvm::ddt(T) == kappa*fvc::laplacian(T)); is an explicit algorithm. fvc:: is always an explicit evaluation of the field. Gavin |
October 22, 2008, 07:43 |
Hi Gavin,
Thanks for your e
Rina Oldek
Hi Gavin,
Thanks for your email. What I ment by explicit algrithm is by the ability to change the time step throughout the simulation depending on the courant number, for example in the case of a pressure wave. Is it possible? Rina |
October 22, 2008, 08:01 |
If you want to use a Courant-b
Niklas Nordin
Rep Power: 29 |
If you want to use a Courant-based timestep you might have to modify the code.
Dont worry, it is very easy. Lets take turbFoam as an example. open up turbFoam.C with your favourite editor and after this line # include "initContinuityErrs.H" add this # include "readTimeControls.H" and after this line # include "CourantNo.H" add this # include "setDeltaT.H" now run wmake to use it you need to edit the system/controlDict by adding these lines adjustTimeStep on; maxCo 0.1; and thats it. N |
implicit or explicit | laure | FLUENT | 2 | June 2, 2007 06:45 |
Explicit Solver | wessels | OpenFOAM Running, Solving & CFD | 1 | September 26, 2005 05:39 |
LES (explicit) filtering | John | Main CFD Forum | 2 | July 29, 2004 18:03 |
explicit formulations | Muhammad zubair | FLUENT | 1 | June 14, 2004 00:44 |
Coupled Explicit | Andrew Parker | FLUENT | 1 | October 12, 2001 07:18 |
