Rise of a spherical bubble terminal velocity
Like Tree5Likes
Old   June 4, 2008, 13:54
Default Update on the case. The veloc
  #21
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Update on the case.
The velocity gradient mentioned above was due to boundary influence.
With a slightly bigger geometry the result is within 1.4 % error of the estimated value of the terminal velocity.
risevelocity.pdf
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   June 6, 2008, 03:44
Default Hi Sebastian I have just fo
  #22
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Sebastian
I have just found a tool called sampleSurface, where you can extract isoSurfaces. Look in the template-dict in
~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/miscellaneous/sa mpleSurface.
Have a nice weekend,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   October 20, 2008, 14:32
Default Hi all, sebastian, thanks
  #23
Azman
azman is on a distinguished road
Hi all,
sebastian, thanks for sharing your case in this forum. at least I know now what to look out when simulating rising bubbles with InterFOAM. I have been playing around with the InterFOAM solver for about 2 weeks now, and was toying with the idea of solving the concentration field of oxygen bubble rising in water using InterFOAM.
I am not sure whether you or anyone have ever tried it.
The first strategy that came to my mind was ..just adding the scalarTransport equation (just like how it was defined in the ScalarTransportFoam) in my InterFoam solver, after the gamma equation and velocity equation is solved.
solve
fvm::ddt(C)
+ fvm::div(U, C)
- fvm::laplacian(DT, C)
with DT = gamma*D02_liquid + (1-gamma)*DO2_air
I am however not sure how I can include a jump condition at the interface, such that CO2_liquidinterface = HenrysKoeff*C02_gasinterface. I fear that this is not possible with the VOF method since VOF doesnt track the interface per se, but just the vol. fraction of each cell, and magically reconstruct the interface. Am I right?
I recently came across a paper from Bothe et al., about direct numerical simulation of mass transfer between rising bubbles and the surrounding liquid that can be accessed through the link below.
http://chemie.uni-paderborn.de/fileadmin/chemie/Arbeitskreise/Warnecke/Literatur /bubblyflows.pdf
In their work with a self-built fvm code, the VOF method was used too, with the PLIC method to reconstruct the interface. The scalar transport equation was solved as follows:
Inside each phases:
dC'/dt + div(C'*u) = DT.grad(C')
whereby C' = C_liq at the liquid phase
C' = C_gas/H at the gas phase
DT (as above)
at the interphase:
C'_L = C'_G
D02_liquid*grad(C').n = H*D02_Gas*grad(C').n
Does anyone know what to include in the solver, such that the condition at the interphase is fulfilled.
azman is offline   Reply With Quote
Old   June 26, 2009, 07:19
isabel
isabel is on a distinguished road
How do you use fundySetFields?
I want to define a spherical bubble of radio 0.001 and center 0,0 and I have typed:
funkySetFields . . -field gamma -expression 0 -time 0 -keepPatches -condition "pow(pos().x,2) + pow(pos().y,2) < pow(0.001,2)"
But I received this error:
bash: funkySetFields: command not found
isabel is offline   Reply With Quote
Old   June 26, 2009, 07:22
ngj
Search this forum, and you will find the place, where it can be downloaded as an add-on to OF. Further you will find a thorough wiki on the subject.
Best regards,
Niels
Old   July 6, 2009, 08:11
Brugiere Olivier
brugiere_olivier is on a distinguished road
Hi all,
I have a bubble and I would like make the same graph than Sebastian. I have find the velocity 's maximun. But now I would like find the cell where this velocity is localise.
Thank's for your help
Olivier
brugiere_olivier is offline   Reply With Quote
Old   July 6, 2009, 09:05
sega's Avatar
Sebastian Gatzka
Originally Posted by brugiere_olivier View Post
Hi all,
Olivier
I have chosen the center of of the bubble for my plots.
Old   July 7, 2009, 02:25
Brugiere Olivier
Thank's to your help, but how do you find the center of the bubble ?
Because I can't fetch your archive barycenter.zip
Old   March 3, 2010, 16:11
sega's Avatar
Sebastian Gatzka
Oh, this has been far in the past.
I was stumbling about your question just today.
Unfortunately I can't fetch the file for myself and I have lost it due to some system error ...
Can anyone post it again?
Old   March 4, 2010, 02:42
isabel
Hi sega,
There is a paper in which is defined the rise velocity: "Thermocapillary motion of deformable drops and bubbles" by Hermann, Lopez, Brady and Raessi.
In this paper, the equation (3.2) is used to compute the rise velocity of a bubble.
Old   January 30, 2011, 04:39
Default rising bubble
  #31
bita
bita.kh is on a distinguished road
Send a message via Yahoo to bita.kh
hi all
i simulate rise of spherical bubble with interfoam,but i can't open cases in this forum,can anyone help me?
bita.kh is offline   Reply With Quote
Old   January 30, 2011, 05:10
sega's Avatar
Sebastian Gatzka
Originally Posted by bita.kh View Post
hi all
If by "Case" you mean "Thread", try to use the "New Thread" button.
Old   September 27, 2011, 09:01
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Hi Sebastian,
I saw in the first post that you used symmetryPlane with interFoam but you found some problems. Did you find ways to fix it? I am also facing problems with using symmetryPlane in interFoam as in my post http://www.cfd-online.com/Forums/openfoam-solving/92524-strange-pressure-behaviour-symmetricplane-boudary-condition-interfoam.html.
I hope to hear your comments on this.
Regards,
Duong
duongquaphim is offline   Reply With Quote
Old   October 26, 2011, 13:39
Default numerical dispersion in OpenFoam
  #34
srikanth
srikanth_b is on a distinguished road
hi Sebastian,
I am a student (new to OpenFoam) and am working on studying the rise behavior of bubbles in sheared liquids. I am using a 3D case without axial symmetry and am simulating flow in a linearly sheared rectangular column.
Due to the large size of the column I am unable to use a mesh with a resolution greater than 10 cells per diameter. I am also facing the same problem of smearing in testcases as fine as 15 cell per diameter.Have you found a way of resolving this.
P.S. I am also working in Fluent and the same mesh works perfectly without any smearing.Is this an advantage of PLIC over Interface compression ?
In anticipation of your reply
Regards
srikanth_b is offline   Reply With Quote
Old   November 1, 2011, 12:12
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
There is a good comparison of the performance of various reconstruction methods here if your interested:
Volume Tracking Methods for Interfacial Flow Calculations, Murray Rudman 1997. International journal for numerical methods in fluids.
I'm guessing the PLIC is saving you from poor interface resolution in the Fluent cases. Unfortunately it's not currently implemented in OpenFOAM although I believe there are some people working on it for structured hex meshes.
kmooney is offline   Reply With Quote
Old   November 19, 2011, 08:26
Default barycenter and drop rise velocity
  #36
Hrushikesh Khadamkar
Hrushi is on a distinguished road
Originally Posted by sega View Post
Hello.
I received a question about how I calculated the terminal velocity.
I have used a post-processing tool I got from the university. I don't know in detail where it comes from, but it was really useful:
barycenter.zip
The tool calculates the location of the mass center of the phase gamma=0 at each timestep.
I tun the tool over my case and put the results into a file named 'center'.
barycenter . . >center
Then I picked the times and positions of the masscenter and calculate the displacement over time which is representing the rising velocity.
Greetings. S.
Hi Sebastian,
I am able to simulate drop rise velocity using interFoam solver. Then I ran barycenter utility as posted above successfully.
I am now stuck at how to extract the time and barycenter coordinate (say in .xy format)?
So that I can calculate instantaneous drop rise velocity over a time.
How did you pick the times and position of the masscenter from center file generated using barycenter utility?
Hrushikesh
Hrushi is offline   Reply With Quote
Old   January 7, 2012, 04:03
sega's Avatar
Sebastian Gatzka
Originally Posted by Hrushi View Post
Hi Sebastian,
Hrushikesh
Well I used
barycenter > center
to produce an output file "center", deleted everything i didn't want manually and imported the data with MATLAB ...
Old   August 21, 2012, 10:53
Default Barycenter utility
  #38
Angelo J. Chaves
A.J.Chaves is on a distinguished road
Hello
I am new here in the forum and I have been working with the same case of the bubble rising. I'm using interDyMFoam and an parallel processing to simulate the case. Now I want to calculate the barycenter of the bubble so I can get the velocity in each step of time. I downloaded the barycenter utility, but when I try to install it, an erro message occurs.
ana@ana:~/OpenFOAM/OpenFOAM-2.1.0/applications/utilities/postProcessing/barycenter$ wmake
Making dependency list for source file barycenter.C
could not open file readEnvironmentalProperties.H for source file barycenter.C
SOURCE=barycenter.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/transportModels -I/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/transportModels/incompressible/lnInclude -I/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/transportModels/interfaceProperties/lnInclude -I/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude -I/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/barycenter.o
barycenter.C:49:44: error: readEnvironmentalProperties.H: Arquivo ou diretório não encontrado
In file included from barycenter.C:52:
createFields.H: In function ‘int main(int, char**)’:
createFields.H:92: error: ‘g’ was not declared in this scope
In file included from barycenter.C:55:
/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/setInitialDeltaT.H:35: error: ‘CoNum’ was not declared in this scope
/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:3: warning: unused variable ‘nOuterCorr’
/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:6: warning: unused variable ‘nCorr’
/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:12: warning: unused variable ‘momentumPredictor’
/home/ana/OpenFOAM/OpenFOAM-2.1.0/src/finiteVolume/lnInclude/readPISOControls.H:15: warning: unused variable ‘transonic’
make: ** [Make/linux64GccDPOpt/barycenter.o] Erro 1
I'm also a new user of the linux system but I guess the erro occurs because I'm using an new version of the OpenFoam (2.1.0) instead the original one that the utility were made for.
If anyone could help me, I would be grateful.
A.J.Chaves is offline   Reply With Quote
Old   August 22, 2012, 01:09
Hi Angelo,
Yes, you are right. You need to make some minor changes in that code. I had done it a year back. I will have to look into my old files. If I get it, I will upload it here asap.
A.J.Chaves likes this.
Old   September 21, 2012, 14:24
Default baryCenter
  #40
Hi Angelo & Tayo
Here is the updated version of baryCenter baryCenter-of201.zip utility. I have tested it on OpenFoam-201. You can comapre the each file in zip archive with one that you have to recognise the changes one needs to make it usable in OF201.
Hope it helps.
Regards
Hrushi
Bubble rise velocity Miguel CFX 1 December 25, 2006 19:17
terminal velocity in spray dryer weekendwarrior Main CFD Forum 1 February 20, 2006 00:47
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
Terminal velocity of 2D rising bubbles Tony Main CFD Forum 0 June 15, 2004 18:37
Terminal bubble shapes Tony Main CFD Forum 0 February 27, 2002 16:30
