Home > Forums > OpenFOAM Running, Solving & CFD
What type return fvcdiv
Old   October 10, 2008, 23:23
Default Hi Ivan fvc::div(...
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Hi Ivan
fvc::div(...) return tmp<geometricfield>
you can use set the variable to the type of geometricfield(including the internal and boundary field, and the data are dimensioned) or just use its internal field(undimensioned).
Hope this helps
Junwei
su_junwei is offline   Reply With Quote
Old   October 11, 2008, 04:07
Default Thank you Junwei for your fast
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Thank you Junwei for your fast reply!
Ok, maybe I found the error, it is in:
volScalarField rhsRho1 = (- divPhiRho1 - rho0 * divPhiU1) / mesh.V();
In someway it doesn't like / mesh.V(), if I remove it, it compiles without errors. But now, 2 questions:
1) If I set a variable like this:
volScalarField a = b;
where b is a tmp<volscalarfield>,
the = assignment is valid?
2) It says that it find some Foam::tmp<foam::field<double> >, and as the only thing I have removed is mesh.V(), the latter should be the tmp, but in the programmer's guide i read that it's a volScalarField. How it is possible?
Bye!!
ivan_cozza is offline   Reply With Quote
Old   October 11, 2008, 08:23
Default Hi Ivan It seems that mesh
su_junwei's Avatar
su junwei
Hi Ivan
It seems that mesh.V() is a dimensionedField,Try the following code segment
volScalarField rhsRho1.dimensionedInternalField()= (- divPhiRho1 - rho0 * divPhiU1).dimensionedInternalField() / mesh.V();
It seems that there is not a member for volScalarField dividing dimensionedField
Junwei
Old   October 11, 2008, 08:26
Default Hi Ivan A little more,
su_junwei's Avatar
su junwei
Hi Ivan
A little more, declare the volScalarField rhsRho1 behand please.
Junwei
Old   October 12, 2008, 09:36
Default I'm a little confused, because
Ivan Flaminio Cozza
I'm a little confused, because the programmer's guide says that the .V() member of mesh should be a volScalarField. Could it be a bug in the programmer's guide?
Moreover, I found out that if I just delete mesh.V() from the right hand side of
df/dt = -div(flux)
it works. The results are coherent! So, the result of fvc::div is already divided by the cell volume?
Have a nice sunday,
Ivan
Old   October 12, 2008, 15:48
Default This is a recent change: mesh.
Hrvoje Jasak
This is a recent change: mesh.V() is now a dimensioned field, ie. it does not have boundary conditions.
Yes, fvc::div(phi) is divided by the cell volume.
Enjoy,
Hrv
Hrvoje Jasak
Old   October 13, 2008, 07:09
Default Thank you Prof. Jasak, now I
Ivan Flaminio Cozza
now I catch this part of the problem.
Cheers!
Thread Tools
Trackbacks are On
return code 2 Kwang-su Kim CFX 5 April 21, 2011 18:03
return code 47 Fernando CFX 0 May 15, 2008 06:29
Return Code 2 - CFX 11.0 AMD 64 Bayard Morales CFX 0 December 5, 2007 09:36
return code 127 Dave CFX 1 September 27, 2006 22:11
Return code 255 (CFX-5.7.1) Jesper CFX 4 May 23, 2005 08:03
