October 9, 2008, 08:42 |
Dear users,
1. How can I st
stephane sanchi
Rep Power: 18 |
Dear users,
1. How can I stop 'properly' a multi-processors job that is running in background ? and maybe also save the results of the last iterations ? 2. Is it possible to plot the residuals while the job is running ? Thanks for helping me, Stephane. |
October 9, 2008, 15:21 |
Have a look at section 4.3 of
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Have a look at section 4.3 of the 1.5 UserGuide:
Replace in the controlDict the current stopAt-Value with writeNow. Save and wait. But be sure not to mistype because then your run might stop without writing anything Bernhard
October 10, 2008, 02:38 |
Thanks Bernhard for your help
stephane sanchi
Rep Power: 18 |
Thanks Bernhard for your help !
Stephane. |
October 10, 2008, 08:59 |
During calculation you can mak
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
During calculation you can make :
reconstructPar paraFoam& You can see the first output and 20min later you can update it : reconstructPar in paraFoam => update content in order to kill a job I use ps to get the PID kill ... Then if you want to start from the last output, you have to modify your controlDict and change the start time. |
October 10, 2008, 09:47 |
For solvers that I use often,
Mark Olesen
Rep Power: 40 |
For solvers that I use often, I've added the following bits of code.
1. At the top bit of the main(), before the time loop starts: // define ABORT file for stopping the job fileName abortName(args.rootPath()/args.globalCaseName()/"ABORT"); if (file(abortName)) { Info<< "removing old ABORT file" << endl; rm(abortName); } 2. In the bottom part of the time loop: runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; if (file(abortName)) { Info<< "reacting to user ABORT" << endl; runTime.writeAndEnd(); } 3. Finally outside of the time loop: // cleanup ABORT file if (file(abortName)) { rm(abortName); } This makes the solver react to the existence of the file 'ABORT' and works well with serial or parallel calculations. It could make a nice functionObject, but to be convenient there'd need to be some way of defining site or user global functionObjects. Eg, via the existing etc/controlDict mechanism, or with a ~OpenFOAM/... directory expansion. I'd certainly want to avoid adding the functionObject to every single system/controlDict! |
October 10, 2008, 10:33 |
Mark,
I am a new user of Op
stephane sanchi
Rep Power: 18 |
Mark,
I am a new user of OpenFoam !!! into which file (controlDict) have you written these bits of code ? Stephane |
October 10, 2008, 14:44 |
Hi Stephane!
Have a look at
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Stephane!
Have a look at the chapter 4 of the user-guide. It is a most interesting read. Especially if you have to ask for the controlDict (which is THE most important file in any OF-case). Trust me. Bernhard
October 13, 2008, 02:36 |
The bits of code have been add
Mark Olesen
Rep Power: 40 |
The bits of code have been added directly into the solver itself (eg, simpleFoam, rhoSimpleFoam, rhoPorousSimpleFoam, etc.)
Stop without res? | Camilo Costa | CFX | 5 | April 17, 2008 22:48 |
Stop solution | Joung Lee | FLUENT | 0 | October 14, 2005 12:18 |
phoenics stop | Olfa Daboussi | Phoenics | 0 | May 26, 2005 04:14 |
Stop iterating | DAE | FLUENT | 0 | January 7, 2004 06:58 |
Where to stop with mesh | Slobodan Pazin | FLUENT | 5 | November 4, 2001 11:17 |
