Home > Forums > OpenFOAM Running, Solving & CFD
Strange Velocity in impeller of MRFSimpleFOAM
Old   April 11, 2008, 03:17
Default The case is on its way! /E
  #21
lillberg's Avatar
Eric Lillberg
lillberg is on a distinguished road
Send a message via Skype™ to lillberg
/E
lillberg is offline   Reply With Quote
Old   April 11, 2008, 04:09
Default Hi what is your dimension for
  #22
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi what is your dimension for omega? 620.823rad/s or 620.832rpm
waynezw0618 is offline   Reply With Quote
Old   April 11, 2008, 04:49
Default MRFZone require rad/s. (You ca
  #23
Niklas Wikstrom
wikstrom is on a distinguished road
MRFZone require rad/s. (You can easily check the correct rotation velocity by looking at the tip velocity of the impeller blades.)
/Niklas
wikstrom is offline   Reply With Quote
Old   April 11, 2008, 05:11
Default Hi Eric: i am not quit sure
  #24
wayne.zhang
Hi Eric:
i am not quit sure about you boundary but aftre 100 and more step the inlet vector looks strange too:
wayne
Old   April 11, 2008, 08:12
Default Looks strange indeed! I'm runn
  #25
lillberg's Avatar
Eric Lillberg
Looks strange indeed! I'm running the case to make sure I haven't made any stupid alterations that prevents it from converging.
Maybe my collegue Niklas can send you one of his cases?
/Eric
Old   April 11, 2008, 09:15
Default Hi Wayne, The case runs jus
  #26
lillberg's Avatar
Eric Lillberg
Hi Wayne,
The case runs just fine here. Just let it run for some 500-1000 iterations, and it will look much nicer. The mesh is so coarse that you'll need to relax k and epsilon substantially (0.01 or 0.001) during the first 200-300 iterations, but it's typical OF behaviour.
Also, you can reduce the non-orthogonal corrections to 0 to prevent the solver from holding on to a bad solution.
/Eric
Old   April 11, 2008, 09:59
Default Hi Eric thanks for you help
  #27
wayne.zhang
Hi Eric
thanks for you help.what i am do not know how to set the boundary in OF, what i always do in CFX is :
inlet -> massflow inlet (etc.Q kg/s)
outlet -> average static pressure (0 pa)
how can i define these boundaries?
thank!
wayne
Old   April 11, 2008, 10:29
Default by the ways what is the SLIP
  #28
wayne.zhang
by the ways
what is the SLIP boundary in your case ?in my case the hub and shroud are all rotating boundary like blade(i patch them in MRFZones file).and in CFX the hub and shroud are always in that way.
any way if possible please let your collegue Niklas send me one of his cases.thanks!
wayne
Old   April 14, 2008, 01:11
Default Hi could you tell me how t
  #29
wayne.zhang
Hi
could you tell me how to use the massFlowrateBoundary condition?
in polymesh/boundary of 0/u?
Old   April 14, 2008, 03:09
Default Hi I add to 0/U: INLE
  #30
wayne.zhang
Hi
I add to 0/U:
INLET
type massFlowRateInletVelocity;
massFlowRate 3.06; // Mass flow rate [kg/s]
the error is
--> FOAM FATAL IO ERROR : keyword value is undefined in dictionary "/home/waynezw0618/OpenFOAM/waynezw0618-1 .4.1/run/impeller/./GS1/0/U::INLET"
file: /home/waynezw0618/OpenFOAM/waynezw0618-1.4.1/run/impeller/./GS1/0/U::INLET from line 33 to line 36.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 146.
how can i dfine the massflowratevelocity boundary?
Old   April 14, 2008, 03:57
Default Add 'value' statement to your
  #31
lillberg's Avatar
Eric Lillberg
Add 'value' statement to your BC in U.
INLET
value uniform 3.06;
Old   April 14, 2008, 08:48
Default Hi Eric what is value uniform
  #32
wayne.zhang
Hi Eric
what is value uniform 3.06refer to? massflow rate or velocity?
thanks
wayne
Old   April 14, 2008, 08:54
Default I'm not sure about the impleme
  #33
lillberg's Avatar
Eric Lillberg
I'm not sure about the implementation, but generally it implies the default starting value of the BC, in this case massflow rate. If you get an error post it here and I'll check it.
//Eric
Old   April 14, 2008, 23:21
Default Hi it still do not works if
  #34
wayne.zhang
Hi
if run without value uniform 3.06; error message is :
--> FOAM FATAL IO ERROR : keyword value is undefined in dictionary "/home/waynezw0618/OpenFOAM/waynezw0618-1.4.1/run/tutorials/icoFoam/inlettry/0/U ::in"
file: /home/waynezw0618/OpenFOAM/waynezw0618-1.4.1/run/tutorials/icoFoam/inlettry/0/U: :in from line 34 to line 35.
FOAM exiting
and if with red{value uniform 3.06; } the error is:
--> FOAM FATAL IO ERROR : Expected a '(' while reading VectorSpace<form,>, found on line 36 the doubleScalar 3.06
file: /home/waynezw0618/OpenFOAM/waynezw0618-1.4.1/run/tutorials/icoFoam/inlettry/0/U: :value at line 36.
From function Istream::readBegin(const char*)
in file db/IOstreams/IOstreams/Istream.C at line 94.
FOAM exiting
i turn to Doxygen,and example of the BC specification::
inlet
massFlowRate 0.2; // Mass flow rate [kg/s]
how to ?
Old   April 15, 2008, 00:18
Default ok, then you need to write
  #35
lillberg's Avatar
Eric Lillberg
value uniform (0 0 0);
/eric
Old   April 15, 2008, 00:34
Default Hi Eric it can run with val
  #36
wayne.zhang
Hi Eric
it can run with value uniform (0 0 0); but it looks like the boundary velocity is defined by (0 0 0),not as a massflowRateInletVelocity. and when i turn to Doxygen,there is no such construct of massFlowRateInletVelocity.
can you tell me the details ?
thanks
wayne
Old   April 15, 2008, 02:35
Default Wayne, As Eric said, you al
  #37
Mark Olesen
olesen will become famous soon enough
Wayne,
As Eric said, you also need to add a 'value' entry to the dictionary. I.e., 'value' for generic initialization (you can consider it a placeholder) and the 'massFlowRate' is used for actually setting the boundary condition as a fixed massflow rate.
At the following iterations you'll see that the 'value' field is indeed filled with the calculated velocity field on the boundary patch.
As for your point
it looks like the boundary velocity is defined by (0 0 0), not as a massflowRateInletVelocity. and when i turn to Doxygen,there is no such construct of massFlowRateInletVelocity.
I'm not sure which documentation you are using, but the version on sourceforge does show construction from a dictionary:
massFlowRateInletVelocityFvPatchVectorField
const fvPatch&,
const DimensionedField ...&,
const dictionary&
If in doubt, you should always take the source code as being authoritative. This is the really beauty of OpenFOAM - the algorithms are open for viewing and you can adjust them for your purposes.
olesen is offline   Reply With Quote
Old   April 15, 2008, 23:38
Default Hi Mark thanks for your reply
  #38
wayne.zhang
Hi Mark
thanks for your reply,for i am not quite familiar with C++.so please excuse my question.
in the construction
\quote {
const fvPatch&,
const dictionary&
fixValueFvPatchField<vector>(p,iF,dict)
and this construction will be initialized by fixValueFvPatchField<vector>(p,iF,dict),and then i turn fixValueFvPatchField to find relative construction.and it is initialized by:
fvPatchField<type>(p,iF,Field<type>("value",dict,p .size()))
and what is the "value" here? how does the "dict" works?
by the way another quesion
in the member function of massFlowRateInletVelocity there is
operator==(n*avgU/rhop)
what is the use of == ? is it overloaded the '==' operator for the volVectorField
type as the "="?
thanks
wayne
Old   April 16, 2008, 02:36
Default Wayne, The dictionary class
  #39
Mark Olesen
Wayne,
The dictionary class *is* explained in doxygen docs. It is also possible to follow the inheritance of the fixedmass patch via the doxygen docs to find out which class has implemented the 'operator==' (not to be confused with the 'operator=').
Perhaps someone else on the forum would be kind enough to do the digging for you and explain it. Otherwise you'll have to do it yourself.
A modicum of C++ knowledge might be useful.
Old   April 16, 2008, 22:30
Default Hi Mark thanks! wayne
  #40
wayne.zhang
Hi Mark
thanks!
wayne
Thread Tools
Trackbacks are On
Equations in the MRFsimpleFOAM waynezw0618 OpenFOAM Running, Solving & CFD 5 May 7, 2015 04:43
Convergence with MRFSimpleFoam grugg OpenFOAM Running, Solving & CFD 7 March 28, 2014 05:56
MRFSimpleFoam xdanielx OpenFOAM Running, Solving & CFD 0 December 17, 2008 02:28
Strange Velocity JoeSa CFX 1 September 28, 2006 09:13
Strange oscillating velocity zonexo Main CFD Forum 2 April 6, 2006 11:38
