Hi every one
i am trying to
Hi every one
i am trying to simulate the centrifugal impeller with MRFSimpleFoam. after about 5000 steps there are strange velocity in only one passage,the velcity is much larger(above 1e +6 m/s). here is the image of vector plot http://www.cfd-online.com/OpenFOAM_D...ges/1/7277.jpg |
and here is the residual
http
Take a look at k and epsilon r
Take a look at k and epsilon residuals and see which starts to diverge first (U, k or epsilon). Then decrease de order of discretization (take upwind for example) for that particular equation.
To be on the safe side use upwind for all of them. Dragos |
Hi Dragos
i will try it today
Hi Dragos
i will try it today and here is the p k and epsilon http://www.cfd-online.com/OpenFOAM_D...ges/1/7282.jpg thanks wayne |
Well Wayne,
It seems that k a
Well Wayne,
It seems that k and epsilon are ok, you have to see which starts to diverge first: pressure equation or momentum? Dragos |
Hi Dragos
it looks like there
Hi Dragos
it looks like there are the same http://www.cfd-online.com/OpenFOAM_D...ges/1/7284.jpg and it quit similar to the iteration procedure in cfx(i will post later,for i am not working on that computer),but there is no such strange velocity. thanks wayne |
Hmm, to me it looks that press
Hmm, to me it looks that pressure starts to diverge first. So you can try to converge better the pressure equation.
Hi Dragos
how to? would you
Hi Dragos
how to? would you mind to tell me more ? wayne |
Hi Wayne,
Is your outflow b
Hi Wayne,
Is your outflow boundary the one in the picture or does it only show a part of the whole model. If it is your outflow boundary, what boundary conditions have chosen for it? Also, post an image of your mesh or the output from the checkMesh utility. Regards //Eric |
I use this seting for the pres
I use this seting for the pressure equation (fvSolution):
p PCG}; tolerance 1e-6; relTol 0.05; maxIter 100;</blockquote> }; </blockquote> |
To Eric:
i use the fixedValue
To Eric:
i use the fixedValue in p for my output condition. the calcualtion region is a impeller without the voulte,so you can see them on the first image! Wayne |
To Dragos
thanks!
i will
To Dragos
thanks! i will try! Wayne |
Wayne,
Your outflow boundar
Wayne,
Your outflow boundary is way to close to the region where things happen to allow for fixed pressure BC. Use totalPressure BC instead together with appropriate BC's for U pressureInletOutletVelocity, k inletOutlet and epsilon inletOutlet. Regards /eric |
Hi:
i try to run the case in
Hi:
i try to run the case in the parallel again without change anything in fvSolution.i still get a divergence. but the different is i donot get strange velocity like before,and the velocity is also looks quiet strange.it looks like that there is no velocity inlet just angular velocity everywhere including the velocity inlet. here is the residual http://www.cfd-online.com/OpenFOAM_D...ges/1/7302.jpg |
and is the velocity in 0.5 spa
and the velocity in 0.5spanwis
Hi Wayne,
Surely looks a bi
Hi Wayne,
Surely looks a bit strange! Could just be a fault in the setup!? What about your makeMesh config, are the faceZones set up properly in the parallel case? I've run dozens of impellers like yours using the MRF and also comparing with sliding mesh simulations (in general < 5% difference in total flowrate) and also tabulated values (generally < 15% difference on coarse meshes). Two things about your simulations tells me you'll end up in trouble sooner or later and therefor should be fixed. Firstly, change the location and/or type of your outflow BC. Secondly, if things don't work in serial runs don't bother doing them in parallel. If your case is too big use a coarser mesh to start with. Also, try the pressure solver settings Dragos showed above. Additionally, run the case with upwind defferencing only for all variables and add "Interpolate(U) upwind phi;" to your interpolation settings in fvSchemes. Good luck, /Eric |
Hi Eric
would you mind to se
Hi Eric
would you mind to send one of your setting(such as makemesh/fvSolution/fcScheme/MRFZones/dynamicMeshDict/Boudary/0 dictionary )or me ? thanks! wayne |
Sure,
Send your e-mail adr
Hi
My email adress is wayne
Hi
My email adress is waynezw0618@163.com i have sent a email to you.if it was too large for you to send me.please send the setting files(such as makemesh/fvSolution/fcScheme/MRFZones/dynamicMeshDict/Boudary/0 dictionary or other)to me! thanks! wayne |
