May 14, 2010, 11:30 |
Problem understanding rhoPisoFoam
Matthias P
Rep Power: 15 |
Hey i'm a newbie in Openfoam and try to understand the solution scheme of the solver rhoPisoFoam.
On of the first equations to be solved is the continuity equation for density included by rhoEqn.H. Now my question is what is solved by that equation and why i have to do so. Later on in pEqn.H the same headerfile is included once more. Why? Maybe somebody can help me understanding this. Thx Matthias |
May 15, 2010, 13:21 |
Alberto Passalacqua
Rep Power: 36 |
The first time you find an updated density at the new time, based on the old flux (see the flux is not recomputed, but the conservative one at old time is used).
In the pEqn, you find the updated density at the new time using the conserved flux at the current time. Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
convergence problem | Trushar | Phoenics | 5 | August 27, 2002 23:40 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
