How to do mapfield for different geoand different solver |
October 1, 2008, 08:51 |
Hi every one
i am doing th
Hi every one
i am doing the numerical simulation about free surface vortex in the forebay of pump station. first i use the "rigid lid" assumption,and solve the case by simpleFoam.and now i want to use interFoam to resolve the free surface by "VOF" method. i want to know how can i run the interFoam with initial value calculated by "rigid lid" assumption.i tried mapField with error like: mapFields LXJ/ snowjieNOVOF LXJ/ snowjieVOF >a --> FOAM FATAL IO ERROR : cannot open file file: LXJ//snowjieVOF/system/mapFieldsDict at line 0. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 66. FOAM exiting [zq602016@cn157 run]$ export FOAM_ABORT=1 [zq602016@cn157 run]$ mapFields LXJ/ snowjieNOVOF LXJ/ snowjieVOF >a --> FOAM FATAL IO ERROR : cannot open file file: LXJ//snowjieVOF/system/mapFieldsDict at line 0. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 66. FOAM aborting (FOAM_ABORT set) #0 Foam::error::printStack(Foam:stream&) in "/var/software/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::IOerror::exit(int) in "/var/software/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::regIOobject::readStream() in "/var/software/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::regIOobject::readStream(Foam::word const&) in "/var/software/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::IOdictionary::IOdictionary(Foam::IOobject const&) in "/var/software/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #5 main in "/var/software/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/mapFields" #6 __libc_start_main in "/lib/tls/libc.so.6" #7 Foam::regIOobject::readIfModified() in "/var/software/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/mapFields" Aborted |
October 2, 2008, 09:38 |
Hello Hrv
would you mind to
Hello Hrv
would you mind to tell me HOW? thanks wayne |
segregated solver vrs coupled solver | sm | FLUENT | 0 | November 6, 2007 01:24 |
about CFX solver | student | CFX | 3 | April 6, 2006 19:02 |
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver | dandes | OpenFOAM Pre-Processing | 0 | March 22, 2006 21:06 |
solver | fuf | FLUENT | 0 | June 19, 2003 13:54 |
coupled solver / uncoupled solver | Jaan Unger | Main CFD Forum | 0 | September 3, 2002 08:30 |
