File bb has modification time 1e04 s in the future
Old   January 31, 2008, 10:14
Default I'm trying to compile the oodl
Christian Lindbäck
christian is on a distinguished road
I'm trying to compile the oodles solver with a few extra lines of code. It worked perfectly fine on my previous work station.
When I execute "wmake" I get the following error message for a number of files:
"File '...' has modification time 1e+04 s in the future"
What is this?
Best regards,
Christian Svensson
christian is offline   Reply With Quote
Old   January 31, 2008, 10:22
Default I've seen that when my working
Mike Long
mplongjr is on a distinguished road
I've seen that when my working directory is being shared over NFS from a different machine.. the clocks on the two machines are not in sync. If that's the case, you can fix it via ntp, either syncing both machines to an internet time source or at least syncing them to each other...
Hope that helps!
mplongjr is offline   Reply With Quote
Old   September 9, 2008, 05:36
Default hi. i have this prolem "warni
Amin Hosseini
omid_7029 is on a distinguished road
hi.
i have this prolem "warning: "has modification time in future + clock skew...." when i am trying to compile each on of solvers.without changing them.
please help me.
regards.
A. H.
omid_7029 is offline   Reply With Quote
Old   September 9, 2008, 11:45
Default Don't worry about it. The cloc
Eugene de Villiers
eugene is on a distinguished road
Don't worry about it. The clock on your workstation is just ahead of the machine used to create/edit the file. This will not affect your results in any way.
eugene is offline   Reply With Quote
Old   September 11, 2008, 02:21
Default Thank you.
Amin Hosseini
Thank you.
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 09:45
time varying BC text file cfd.toy CFX 0 April 22, 2008 10:03
file with data of temperature and time Rogerio Fernandes Brito CFX 4 January 10, 2008 17:44
Variable value with time - from SOLVER FILE Tuks CFX 4 July 11, 2005 05:49
Modification in a Time Dependent Velocity Guillermo Solano Phoenics 4 April 8, 2002 03:34
