Division by zero
Like Tree2Likes
  • 2 Post By hjasak
Old   August 28, 2008, 02:52
Default Hi. I have a volVectorField U
Dragan Vidovic
vitke is on a distinguished road
Hi. I have a volVectorField U and I'd like to make a volTensorField D=(U*U)/mag(U) whenever mag(U)!=0 and zero otherwise. Is there any way to accomplish this simple task?
vitke is offline   Reply With Quote
Old   August 28, 2008, 03:31
Default volTensorField hrv = U*U/stabi
Hrvoje Jasak
volTensorField hrv = U*U/stabilise(mag(U), SMALL);
Hrv
chegdan and lbossle like this.
Hrvoje Jasak
Old   August 28, 2008, 04:29
Default Thanks Hrvoje. But it does not
Dragan Vidovic
Thanks Hrvoje. But it does not work, and it gives a complicated error message, which, I guess, says that mag(U) gives a GeometricField, and stabilise expects an UList:
Making dependency list for source file thermohaline.C
SOURCE=thermohaline.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home/dvidovic/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/dvidovic/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/dvidovic/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/thermohaline.o
In file included from thermohaline.C:45:
createFields.H: In function 'int main(int, char**)':
createFields.H:130: error: call of overloaded 'stabilise(Foam::tmp<foam::geometricfield<double,> >, const Foam::scalar&)' is ambiguous
/home/dvidovic/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/scalarField.H:72: note: candidates are: Foam::tmp<foam::field<double> > Foam::stabilise(const Foam::UList<double>&, Foam::scalar)
/home/dvidovic/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/GeometricScalarField .C:87: note: Foam::tmp<foam::geometricfield<double,> > Foam::stabilise(const Foam::tmp<foam::geometricfield<double,> >&, const Foam::dimensioned<double>&) [with PatchField = Foam::fvPatchField, GeoMesh = Foam::volMesh]
make: *** [Make/linux64GccDPOpt/thermohaline.o] Error 1
Old   September 1, 2008, 03:47
Default Hi Dragan, have you found a
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hi Dragan,
have you found a solution for this problem? I'm dealing with the same errors.
Regards
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   September 1, 2008, 04:44
Default Hi Kathrin Yes, this is wha
Dragan Vidovic
Hi Kathrin
Yes, this is what I did:
(U*U)/(mag(U)+SMALL*UUnits)
And UUnits is this:
dimensionedScalar UUnits // Velocity units
"kUnits",
dimensionSet(0,1,-1,0,0),
1.0
I don't know how small is SMALL, I hope it's small enough. I'd prefer to modify mag(U) only when it is smaller than SMALL, but I don't think this is worth any more trouble. Of course, if you want to compute this often, then put SMALL in the dimensionedScalar.
Good luck
Dragan
Old   September 1, 2008, 05:35
Default Hi Dragan, thank you! It
Kathrin Kissling
Hi Dragan,
thank you! It works now!
Best regards
Kathrin
About flow division sunnysun OpenFOAM Running, Solving & CFD 5 March 2, 2009 12:34
Rather obscure division by zero in triangleFuncsintersectAxesBundle gschaider OpenFOAM Bugs 2 August 13, 2008 07:08
Division by zero in Xoodles hannes OpenFOAM Bugs 3 August 4, 2008 11:04
ScalarField division maka OpenFOAM Pre-Processing 2 August 27, 2007 05:10
