hi,
when i run the case of rh
hi,
when i run the case of rhoTurbFoam,i get Reading thermophysical properties Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>> #0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) #1 Foam::sigFpe::sigFpeHandler(int) #2 Uninterpreted: [0xb7f01420] #3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() #4 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::hThermo(Foam::fvMesh const&) #5 Foam::basicThermo::addfvMeshConstructorToTable<foa m::hthermo<foam::puremixture<f oam::consttransport<foam::speciethermo<foam::hcons tthermo<foam::perfectgas> > > > > >::New(Foam::fvMesh const&) #6 Foam::basicThermo::New(Foam::fvMesh const&) #7 main #8 __libc_start_main #9 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122 what is wrong?i will be very appreciate if someone tell me. |
is there a zero somewhere in your initialisation? Maybe the pressure?
neewbie |
