August 27, 2008, 05:36 |
In my model, I need
Ivan Lau
Rep Power: 17 |
In my model, I need to have two different wall functions because two walls have significant different roughness. Is it possible? Thanks, iL |
August 27, 2008, 07:57 |
Yes, it is definitely possible
Niels Gjoel Jacobsen
Rep Power: 37 |
Yes, it is definitely possible, as you just define the two boundaries with another type or different properties than those of the other boundaries.
If such a boundary condition is readily available in OF I do not know. It should be fairly straight forward. Try to look into the k-omega for rough surfaces posted in http://www.cfd-online.com/OpenFOAM_D...es/1/5791.html but be careful I am advertising for my own work and it has not yet been tested/verified. Best regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
August 27, 2008, 12:36 |
Hi, Niels,
Thanks for your
Ivan Lau
Rep Power: 17 |
Hi, Niels,
Thanks for your reply. I just looked at your thread. However, I am actually looking for some simpler solution. Currently, there are variables "kappa and E" under wall function of k-epsilon models. I thought I can simply specify different E (small E for smooth surface and higher E for rough surface). I guess I need to modify the code to achieve this. Am I correct? Best Regards, iL |
August 27, 2008, 13:43 |
I do not know, as I have not u
Rep Power: 37 |
I do not know, as I have not used in "build-in" wall function, and thus have not spent time looking into the source.
Best regards, Niels
How can I add a new wall function | imano | OpenFOAM Running, Solving & CFD | 14 | September 17, 2015 08:53 |
Bug in wall function | rolando | OpenFOAM Bugs | 7 | June 8, 2007 04:51 |
wall function | Alex | CFX | 9 | May 19, 2005 10:05 |
Does RSM use wall function? | Sam | Main CFD Forum | 4 | March 2, 2005 23:58 |
Wall function | Min-Hua Wang | CFX | 4 | July 5, 2002 12:13 |
